Sponsored by:
Sponsored by: CARiD
ETS Intake install problem
Old Jan 5, 2012 | 09:32 PM
ericjai113's Avatar
Got my ETS intake from Jordan @ Defined Performance, super fast shipping and great price!
The install is a bit difficult, but everything went in as expected. After the install, I notice the hardpipe is rubbing against the red plastic positive terminal cover. I tried to readjust all the coupling but it is still rub against the plastic. I had to ghetto fix by putting some extra thick foam tape over the area that touches.
Anyone had this issue when they install the ETS intake?
Old Jan 5, 2012 | 09:38 PM
3K's Avatar
3K
Why don't you trim the blow off hose a little so its straight and that should give you more room to clear the terminal cover.
Looks good though.
Old Jan 5, 2012 | 09:49 PM
J Dog's Avatar
^what he said. Looks like the hose is pressing the hard pipe into that terminal.
Old Jan 5, 2012 | 09:50 PM
ericjai113's Avatar
The hardpipe is rigid and the whole assembly is hold in place with the heat shield, so by trimming the flexible BOV hose will not do anything.
Old Jan 6, 2012 | 05:29 AM
DANNY08GSR's Avatar
Mine is DAMN close to hitting it, but it doesn't. Try twisting it a little. Make sure the BOV tube is coming straight out to ensure it is aligned properly.
Old Jan 6, 2012 | 08:36 AM
ETS Michael's Avatar
This is correct. You can twist it a bit in the coupler. It's close, but it shouldn't touch. You should be able to loosen up the coupler and twist the pipe to the correct location and while holding the pipe tighten the coupler back down. Then bolt the heat shield down and hold the pipe into place. we use a mandrel bend on the intake so we don't restrict flow with any cut and welds or reductions for maximum performance.
Any other questions, let me know!
Thanks,
Michael
Old Jan 6, 2012 | 11:54 AM
Alkor's Avatar
Yep. Initially mine was touching but I perfected the fitment in the coupler and now it's still very close but not touching. Loving the intake. Going to get my first tune right after work today!
Old Jan 6, 2012 | 12:30 PM
ericjai113's Avatar
Did you push the coupler that connects to the turbo all the way in? and is your heat shield mounting tap bend upward at the connection point to chassis (not the one connect to the back of the intake)?
With a proper install, the rubber hose to BOV should be straight? And from the different install pictures i have seen, some people are further away from terminal cap while other are close to it. Should the coupler fit over the point that touches the terminal cap?
Old Jan 6, 2012 | 12:51 PM
Alkor's Avatar
I tried to push the main coupler as far as it would go and as straight/even as possible on the turbo inlet. My BOV hose is bent slightly upward/skyward coming from the intake pipe. The MAF housing coupler is the closest thing to the terminal cap on mine. I'd say the coupler itself is about 2-3 mm from the red plastic.
Old Jan 7, 2012 | 05:20 PM
shawnburch's Avatar
Mine is very close too. I just installed it a week ago and havent had time to play with it to get it further way.
lostjounin
Feb 29, 2012 04:05 PM
BPAuto
31
Mar 30, 2011 04:18 PM
raytrix
Aug 1, 2010 02:28 PM
Hakmeister
Aug 23, 2009 03:57 PM
Hydrolikz
Nov 15, 2007 07:27 AM
