Sponsored by:
Sponsored by: CARiD
MR Vs GSR
Old Feb 13, 2012 | 11:57 AM
FutureEvoX's Avatar
MR Vs GSR
whats better guys help me out i think i want a GSR though then when i buy the performance kits from ams...stages 0-2 should I buy them all at once?
thanks
Old Feb 13, 2012 | 12:19 PM
Alpha X's Avatar
This has been posted numerous times. Not trying to be a jerk but try searching for the topics on this.
Old Feb 13, 2012 | 12:29 PM
PRS's Avatar
PRS
if your looking to mod it buy a gsr over the mr.
Old Feb 13, 2012 | 01:34 PM
vanilla2's Avatar
It really depends on you hp goals not everyone is shooting for 500 or more. MR is fine for me cuz I don't plan on ever going over 400 and even then I'm sure some breakthroughs with the tranny will have happened to help push the numbers higher.
Old Feb 13, 2012 | 02:52 PM
nismo2evox's Avatar
From what I have read on the modding front, the GSR is the way to go. That transmission is solid and will hold up to a lot more abuse/power than the SST.
Not saying the SST isn't great or isn't by any means capabile. The manual transmision is just stronger.
Plus the GSR is about 100lbs lighter I believe and can genearate slightly better performance numbers due to the weight difference (other than factors that include shifting speed)
Old Feb 13, 2012 | 03:15 PM
user 629782012's Avatar
quick story about shifting.. and the MR SST
a buddy of mine has a gen coupe v6 supercharged with a low'ish boost 7-10psi.. doing like 380hp or so hp.. my MR is nearly stock with cobb ap.. in the 1/4 mile @ 1150m above sea level i'm running 13.426 with launch control.. he was running 13.6 13.8 all night..
As fast as somone thinks they can shift.. the sst does a freeking great job with shifting + no boost loss.
obviously if you have a GSR with mega power and supurb shifting you can be in the 11's or less...
but i'm just saying that when going agaisnt cars with similar power with even a great driver.. the MR does have a slight advantage in the shifting department.
ps little trick instead of letting launch control shift for ya at red line.. set the cobb AP up so it flashes at ya around 5800rpm.. by the time you tap the shifter you'll shift around 6800 ish.. which seems like it's a tiny bit more boost.. as it tapers way down at 7+k rpm.. I seemed to get about a 10th faster doing this than just letting the auto handle all the shifting.
Old Feb 13, 2012 | 03:44 PM
Robevo RS's Avatar
i make it easy, daily driven car MR , track use GSR.
Old Feb 13, 2012 | 04:36 PM
tkromer's Avatar
Rob nailed it.
Although by "track" he means driving track, if it's a drag strip, the automatic wins there too.
Old Feb 13, 2012 | 04:47 PM
RAzero's Avatar
I personally love daily driving with the SST. I think if you're not going for crazy amounts of power it's a winner.
Old Feb 13, 2012 | 05:43 PM
FutureEvoX's Avatar
Thanks guys sounds like im going with the GSR anyway i know things may be posted and i dont wanna sound like im being an *** back to ya but i only have two posts and im just wondering about stuff if i can keep it in mind ill check the search box next time... thanks to all
Old Feb 13, 2012 | 06:33 PM
Fuego's Avatar
I have the SST and l love it. My wife loves it to because she hates driving manual. lol. I do want to do more power but slowly I will get there. Hopefully when i'm ready for bigger turbo they will have more options by then. I know SSP is doing great work with it. Just waiting for more reviews on it.
Old Feb 13, 2012 | 06:45 PM
Royal Evo's Avatar
off topic...between MR and GSR, does anyone know how much is the difference in maintaining or replacing an SST as compared to a regular clutch? Can someone please give some numbers? If replacing a clutch cost xxx, how much for SST? Thank you.
Old Feb 13, 2012 | 08:34 PM
Crester's Avatar
Isn't the MR faster than the GSR because of the transmission?
I think it comes down to if you want to row your own gears or mod for big power get the GSR...
If you want a good daily driver or want a dual clutch transmission... get an MR.
Old Feb 13, 2012 | 08:39 PM
migs647's Avatar
Sorry guys this has been beaten into the ground. Please search.
/Closed
