Sponsored by:
Sponsored by: CARiD
What RPMs do you shift at?
Old Feb 29, 2012 | 08:42 PM
  #31
tlsole's Avatar
usually like to keep it around <3k when im driving normal, 4-5.5k sprinted, and 7300 rpm when im on it.
Old Feb 29, 2012 | 08:50 PM
  #32
01CBR929's Avatar
I never really pay attention unless I'm getting on it... if that's the case... 8100ish.
Old Feb 29, 2012 | 08:58 PM
  #33
PKEVO8's Avatar
Originally Posted by FJF
I shift anywhere between 4-7K, depending on the situation and the mood. The car rarely dips below ~3.5K.
I could not agree more with this statement
Old Feb 29, 2012 | 10:36 PM
  #34
AFD's Avatar
AFD
Originally Posted by ImEv0
yup, page 3-88.
Found it.. it's pages 3-92 & 3-93 in my manual.
UPSHIFTING
For the best fuel economy and performance in using your manual transaxle, upshift as listed below.
Shift point Upshift speeds
1st gear to 2nd gear 15 mph (24 km/h)
2nd gear to 3rd gear 25 mph (40 km/h)
3rd gear to 4th gear 40 mph (64 km/h)
4th gear to 5th gear 45 mph (72 km/h)
DOWNSHIFTING
It is recommended that you downshift to a lower gear when needed to maintain the desired speed, according to the table. Avoid downshifting at too high a speed. The engine may suffer damage.
To maintain a safe speed and prolong brake life, shift down in 2nd or 1st when descending a steep hill.
Downshifting is also important to avoid "lugging" the engine at too low a speed, such as when turning a corner or when driving up a steep hill.
Recommended downshifting speed
Downshifting speed Shift point
Under 20 mph (32 km/h) Shift down from current gear to 2nd gear.
20 to 30 mph (32 to 48 km/h) Shift down from current gear to 3rd gear.
DRIVING PRECAUTIONS
  • The table below shows the maximum recommended driving speed for in each gear. Do not drive near or at these speeds for prolonged periods of time.
Maximum possible driving speed
Shift points Maximum possible driving speed
1st gear 37 mph (60 km/h)
2nd gear 55 mph (90 km/h)
3rd gear 74 mph (120 km/h)
4th gear 99 mph (160 km/h)
  • Do not use the gearshift lever as a handrest. This can result in premature wear of the transaxle shift forks.
Old Feb 29, 2012 | 11:28 PM
  #35
hkumar's Avatar
I just switch between the different SST modes for the different moods.
Old Mar 1, 2012 | 01:02 AM
  #36
Psycho719's Avatar
I usually shift around 2.5-3k in city. Merging on the freeway maybe a little higher like 4-5.
Old Mar 1, 2012 | 01:44 AM
  #37
4g63gringo's Avatar
I shift between 2500 to 3500 normal driving and redline when getting on it, thats what its made for!!!
Old Mar 1, 2012 | 02:09 AM
  #38
rufiio215's Avatar
i try to keep it under 3500 on daily driving... 6500-7000 when i'm getting after it
Old Mar 1, 2012 | 07:53 AM
  #39
Noize's Avatar
EvoM Administrator
2nd gear 44 mph (90 km/h)
If the manual says that, it's way off. Especially second. Here's the max speeds at redline for a GSR on stock tires rounded to the nearest tenth:
1st gear- 40 mph
2nd gear- 59 mph
3rd gear- 79 mph
4th gear- 104 mph
5th gear- 150mph
Here's the speeds at the stock (GSR) rev limiter of 7599rpm:
1st gear- 43 mph
2nd gear- 64 mph
3rd gear- 86 mph
4th gear- 113 mph
5th gear- 163 mph
Hold fourth deep baby, because fifth sucks!
Old Mar 1, 2012 | 12:09 PM
  #40
H8ted1488's Avatar
DD is around 2.7-3k, agressive is around 4-4.5k. I know this is going to sound really stupid, but I never redline my car... Don't feel the need
Old Mar 1, 2012 | 04:52 PM
  #41
AFD's Avatar
AFD
Above that table it says "maximum recommended driving speed"
So for some reason Mitsu doesn't want us redlining 2nd gear.. not sure why.
You happen to know the RPM equivalent for their recommended upshift points?
Old Mar 1, 2012 | 05:52 PM
  #42
Noize's Avatar
EvoM Administrator
Sure. If you look closer, the RPM would align if second gear was listed as 54mph. I think this proves there is a misprint in the manual.
All of those numbers land exactly on or very close to 6000rpm. 4th is actually at 6200.
I've always thought a manufacturer's never exceed speed was their rev limiter, and even that can be exceeded in some applications safely. Both the 4G63 and 4B11 manual transmission cars cut right at 7600 (7606 and 7599 to be exact per Ecuflash).
Old Mar 1, 2012 | 08:33 PM
  #43
mp72's Avatar
For me it’s not so much what rpm I shift at, but how quickly I build rpm’s.
For daily driving I go easy on the throttle, build rpm’s slowly and shift around 3.5k - 4.5. When approaching a wide open freeway onramp, I’ll occasionally get on it and WOT up to 5k-6.5k. Rarely do I ever reach 7k.
If I ever track my car, I’ll probably hit 7k in every gear.
Old Mar 1, 2012 | 09:14 PM
  #44
ice1874193's Avatar
Why did you guys buy an evo and shift under 3500?
Old Mar 2, 2012 | 06:42 AM
  #45
Mako_7's Avatar
DD-3-3.5K, AGR-4-5K, haven't had anyone wanting to race me yet, they just give me the thumbs up and slow down! LoL
