Sponsored by:
Sponsored by: CARiD
ETS quiet exhaust and a test pipe... Too loud. Ideas?
Old Mar 14, 2012 | 01:01 PM
s2krn's Avatar
Lightbulb ETS quiet exhaust and a test pipe... Too loud. Ideas?
My current exhaust set up is too loud. I have two kids and really need to quiet the car down a bit. It's hard to hold a conversation in the car and the back seat is too loud for the kids. I had an EVO 8 with buschur exhaust and a magnaflow muffler running a down pipe and test pipe previously... my X is significantly louder.
Currently I have an Ultimate Racing down pipe and test pipe mated to an ETS V2 Quiet Exhaust. Honestly I thought this set up would be a "quiet" option, but it is really loud.
I'm considering the UR mini muffler test pipe, but I'm not sure how much of a difference that will make. Has anyone switched from a TP to this? Is it barely noticeable or does it make a significant difference? Searching on here I found that people like the UR mini muffler test pipe, but haven't quite got my question answered. Anyone with my set up that has switched??
I don't really want to switch to a high flow cat, but will if thats what it takes. Just don't want to waste 300 bucks on a mini muffler if its not going to be a noticeable change.
My kids thank you for any help!!!!!
Old Mar 14, 2012 | 01:02 PM
Snakes709's Avatar
put a resinated test pipe in, that should do the job.
Old Mar 14, 2012 | 01:27 PM
icrnk's Avatar
wrong car
Old Mar 14, 2012 | 01:32 PM
Kracka's Avatar
Those are for the 8/9, this is the X section. Did you even read the first post?
Old Mar 14, 2012 | 01:34 PM
ProjectGSX's Avatar
If you have an ETS exhaust and its too loud, I would think you should call ETS. Surely they would have the best range of options to quiet down their exhaust. Just IMO - Michael @ ETS is great help.
Old Mar 14, 2012 | 01:36 PM
ithveno339jfkj4kjekjqqqq's Avatar
solution: sell me you ets catback and put your stock catback back on...
Old Mar 14, 2012 | 04:19 PM
ugakirk's Avatar
Have you thought about a HFC? You don't have any leaks do you? I wouldnt think that quiet version should be too loud.. If it is, then I guess you could just use the stock Catback..
Old Mar 14, 2012 | 07:17 PM
black E's Avatar
The mini muffler test pipe is MUCH quieter then both the resonated test pipe and a HFC, I've had them all....
The mini muffler is the best option.
Old Mar 14, 2012 | 07:29 PM
Alpha X's Avatar
I like loud just dont like the smell the test pipe generates :/
Old Mar 15, 2012 | 08:57 AM
ETS Michael's Avatar
The test pipe does make a decent difference, if the quiet system is too loud the only real option you have is adding a HFC to quiet down the system. The test pipe w/ resonator does not work all that well, it does change the note, but it doesn't quiet it down much. The 3.0" diameter resonator takes effect around 5000rpm+ where a 2.5" seems to take place around the 2500rpm range. It's all based on sound waves and resonance frequency. The HFC does add a restriction into the system and changes the note.
Michael
Old Mar 15, 2012 | 09:01 AM
philamthebest's Avatar
I have a resonated test pipe and after my last tune, the car is so quiet i had a mini muffler and that was too quiet. Was the exhaust put in after a tune? Try the UR resonated test pipe.
Old Mar 15, 2012 | 09:15 AM
jake92695's Avatar
I have a V2 Quiet with a 100 cell HFC and AMS downpipe and it is loud. I like it that way though. I don't know if a HFC option would make it significantly quieter.
Old Mar 15, 2012 | 09:33 AM
Iowa999's Avatar
Michael
Michael -
Have you tried putting the resonator right in front of the rear axle? As you know (so I'm saying this for others, not to insult you), the effects of a resonator depends not only on size and such, but also on location. From what I can tell from spending hours looking at the designs of Evo X exhausts, the quiet ones either are small (which will push back the optimal location to the point of being in the actual muffler, so that works) or have a resonator before the rear axle. It has always surprised me that your system, designed to be quiet but also 3", doesn't have a resonator in front of the rear axle.
- Jt
Old Mar 15, 2012 | 09:38 AM
linjy2's Avatar
I always thought the ETS quiet was loud even for a quiet exhaust. I do like the sound though.
For quiet I still prefer my T1R exhaust. Full 3" with resonated testpipe.
It's quiet compare to the Buschur, ETS, and UR exhaust I heard.
Here is a thread with pics of how the T1R exhaust is designed. Super quiet and only aggressive at WOT. Good for a daily.
https://www.evolutionm.net/forums/ev...pics-lots.html
Old Mar 15, 2012 | 09:59 AM
RevLimiter's Avatar
trade your exhaust for my T1R haha, My exhaust with test pipe not loud at all. almost stock like until WOT.
