Sponsored by:
Sponsored by: CARiD
Alignment.
Old Apr 5, 2012 | 10:47 PM
eboylution's Avatar
Alignment.
I recently got my car align but still whenever i center my steering wheel my car is turning to the right. 2 days after my alignment i took it back to the shop to get it fix now the guy behind the desk is saying that my front right camber cannot be adjusted and i was gonna need a camber kit and was charging 160 (60 for repair kit, 100 for labor) do i really need the kit? to get this fix?.. btw where can i find the stock alignment i'm planning to go back and get them set the alignment to the factory spec. My car is a year 2008 evo gsr. I attached the alignment Report after they did my alignment.
Old Apr 6, 2012 | 05:09 AM
ithveno339jfkj4kjekjqqqq's Avatar
are you lowered or on stock spring/shocks?
if stock, maybe you have a bad shock?
Old Apr 6, 2012 | 05:28 AM
Robevo RS's Avatar
If you didnt had a problem like this before you rolled in they shop, then they messed upsomething.they also should have a stock specs for your car, if they are even slightly good.
Old Apr 6, 2012 | 07:02 AM
Iowa999's Avatar
I've seen this before. The car wasn't level. In this case, it would be listing to the left. And, if that's true, what they did to your rear camber is very bad.
Old Apr 6, 2012 | 09:50 AM
Johnr352's Avatar
I agree. The numbers are poor. Your decision is, unfortunately, not that easy. It appears they are not particularly good at aligning the Evo so even if you complain the best you can hope for is an alignment from a shop that doesn't do particularly good work.
If you leave and just take it to another shop they will start over and charge you again.
If it were me, I'd walk away and explain what happened to a new shop, maybe they will give you a deal.
LakerRaider
12
Aug 9, 2009 06:16 PM
Clipse3GT
12
Jul 25, 2009 01:26 AM
nala
Jun 11, 2009 06:22 AM
Dem1K
Lancer Troubleshooting
Jul 21, 2002 12:44 PM
