Sponsored by:
Sponsored by: CARiD
compare uicp to all companies
Old Apr 20, 2012 | 09:49 AM
Uscbryan's Avatar
From what I have read upper makes no difference but the lowers do. But I am not sure, as with everything on cars, others will say something different. It looks better though, that I think we all agree on.
Old Apr 20, 2012 | 10:00 AM
ugakirk's Avatar
Totally wrong. That is true for the 8 & 9s but on the Evo X, the upper one is the one you need to replace. You want to get rid of that big rubber part of the intercooler pipes.
Old Apr 20, 2012 | 10:09 AM
mlambert890's Avatar
Ive got the AMS UICP and like it (I like all of their stuff), but Im really skeptical about any gains honestly. I consider it engine bay dressup.
Old Apr 20, 2012 | 10:35 AM
Alpha X's Avatar
I went with ETS flat black upper and lower IC piping. They offer a 10% discount on most parts for military
Old Apr 20, 2012 | 10:54 AM
RevLimiter's Avatar
Im also running an AMS polished UICP. theres a thread that confirms the stock UICP expanding under pressure.
Old Apr 20, 2012 | 11:06 AM
ithveno339jfkj4kjekjqqqq's Avatar
Originally Posted by S2K2EVO
So are the gains in the rear upper pipe? Would have a bigger gain if any going full UICP as opposed to just the rear upper piece?
the rear upper OEM piece is where it necks down from 2.5" to 2". this is where the restriction is...
two piece vs one piece is a little controversial. one piece will definitely flow better (in theory). also, you have one less spot for potential boost leak... on the other hand, people worry that a one piece is too rigid and doesn't have enough play for the vibrating/rocking engine.
Old Apr 20, 2012 | 12:18 PM
Noe18's Avatar
I wonder if I can get 10% discount because I'm a member of evom for years, also so just replacing oem with single pipe should be the same gain as 2 piece?
Old Apr 20, 2012 | 12:28 PM
Noe18's Avatar
Wait I thought by changing oem with hard pipe you'll get faster spool? And better throttle response Correct me if I'm wrong
Old Apr 20, 2012 | 12:44 PM
EuroEclipse's Avatar
The hard pipe will enhance turbo spool and throttle response, yes. Mainly, the stock pipes could potentially collapse under higher boost pressure causing a huge restriction in airflow.
1.75" to be exact.
Old Apr 20, 2012 | 01:30 PM
bLiTzKrG's Avatar
Originally Posted by bowrepublik
this thread is all about opinion...
I prefer the cobb turbo inlet hose and hard pipe kit over the others. it was also easy to install. they have seemed pretty bomb proof so far.
I have the same Cobb setup (and color). Liked it being aluminum and one piece. This kit comes with UICP / LICP / and turbo inlet as started. Probably only need the UICP which will save some $$. Think if you stick with a rep brand (Cobb, ETS, AMS, or Speed Circuit) - you really can go wrong.
Old Apr 20, 2012 | 01:40 PM
Noe18's Avatar
^^ you mean I can't go wrong lol, but that want I'm think I don't need licp so I'm think about getting ets rear pipe
Old Apr 20, 2012 | 01:54 PM
surefooted's Avatar
From the "other" forum:
Originally Posted by Jeremy(at)SSP
Wow....great price ($100 for UICP).
Originally Posted by Tim(at)DepoRacing
...Its not cheap, its the appropriate price for a bent tube,lol.
Rofl....well put sir.
Old Apr 20, 2012 | 02:00 PM
brenner's Avatar
my friends cobb piping had cracks in it.
take that for what you want.
Old Apr 20, 2012 | 07:51 PM
Noe18's Avatar
^^ i guess its not bomb proof LMAO
Old Apr 21, 2012 | 01:05 AM
alex the great's Avatar
In theory yes, there would be gains but less than 1hp. You wont feel any difference on anything at least I didnt. Its just a pipe so it wont do mucn. I replaced mine becasue the OEM uicp is garbage and it also expands. The ETS uicp is 10/10 on quality, looks, and fitment.
