Sponsored by:
Sponsored by: CARiD
daytime running lights problem, maybe
Old May 22, 2012 | 10:57 PM
Evolution_10's Avatar
So I recently purchased my car. Did not really notice anything wrong with it. My sister bought her evo x 1 week after I did. I notice when her lights are off, her daylight lights are on. At first I did not even know evo x came with running lights. So I noticed my daytime lights do work when i unlock or lock my car. But don't work when i drive. Can anyone help me out with this. Thank you\
-Noob
Old May 22, 2012 | 11:53 PM
nonocei's Avatar
I'm assuming you purchased the car used? If so, do you know if your x came with the "SSS" package (hids, Rockford fosgate system and larger spoiler)? I have seen issues with drls when the hids from the SSS Evo were installed in a non SSS Evo.
Old May 22, 2012 | 11:58 PM
Sorry for the lack of info. But yes my car was purchased used and it is the SSS package. (hids, rockford fosgate system, and larger spoiler).
Old May 23, 2012 | 08:52 AM
TheBlade's Avatar
I have SSS and my DRL works great
Old May 23, 2012 | 09:11 AM
Well that doesn't help LOL
Old May 23, 2012 | 10:42 AM
Alpha X's Avatar
Perhaps u need new bulbs?
Old May 23, 2012 | 10:49 AM
yoshe200's Avatar
When I bought my car used, the original owner had pulled the fuse for the DRL. I'd check the fuse as well as the bulbs.
Old Jul 19, 2013 | 01:48 PM
yogr81's Avatar
I have a 2011 EVO X GSR with the SSS and my DRL on my passenger side doesn't come on. I changed the blub and even changed the fuse. Still doesn't turn on. Only my drivers side does. I wanted to ask before I take to the dealer. I believe I still have my warranty, but I wanted to try to fix the problem myself first. Sorry for the noob question.
Old Dec 14, 2013 | 10:45 PM
G-4ce_Banger's Avatar
^Bump for someone to chime in on this please?! I've had my headlights blacked out for a few years and they've always burned out relatively quickly but I really like the look with the amber bulbs. It went out recently and I can't figure out why it's not getting power. And yes I replaced the bulb, I checked the plug and it's not getting power.
Old Dec 15, 2013 | 08:26 AM
-Quick-'s Avatar
Did you check for power at the fuse?
If you have power before the fuse, that means its an issue some place after that. Such as the fuse or wiring etc.
Old Dec 15, 2013 | 09:18 AM
Kahrs's Avatar
I've heard that there are features in the ECU/ETAC that disable and enable some of these options. Is it possible that different cars have different settings?
Old Dec 15, 2013 | 01:57 PM
Iowa999's Avatar
Yes, you can disable the DRLs via ETACs, but you can't turn off one and leave the other on, so that could only be the issue if both aren't working.
Old Dec 15, 2013 | 02:10 PM
Kahrs's Avatar
My bad was just a thought.
Old Dec 16, 2013 | 10:56 AM
I saw what I thought was the fuse in the main fuse box in the engine compartment but it looked more like a relay to me so I wasn't sure how to check the power on it. Also I have power to the drivers side so I figured it wasn't blown. Should I try to figure out which wire coming from the main fuse box goes to the passenger side drl? That seems like it might be difficult but I guess nobody said it was gonna be an easy fix.
Old Dec 16, 2013 | 11:15 AM
Spazpilot's Avatar
It could be your relay. I believe its the same as your fuel pump one. if that's the case I would also change out your fuel pump relay. They are know for going bad. SSP sells a kit of six to change them out for the new ones.
