Sponsored by:
Sponsored by: CARiD
Quick Intercooler Question.
Old Jun 28, 2012 | 10:17 AM
PonoPride's Avatar
Ok just as the title says, because ive being searching and cang find a concrete answer. When and why would you replace the stock intercooler. From my undersranding its pretty decent.
Old Jun 28, 2012 | 10:22 AM
b3n's Avatar
b3n
When you upgrade the turbo, otherwise it really isn't needed.
Old Jun 28, 2012 | 10:54 AM
Kracka's Avatar
An upgraded intercooler is never a bad idea, especially in a warm climate; cooler intake air temps and more power, even on a stock turbo.
Old Jun 28, 2012 | 02:28 PM
odin's Avatar
Lightbulb
^ +1
Well addressed!
Old Jun 28, 2012 | 06:50 PM
evo_xtc2011's Avatar
Great answer Chris. Nothing wrong with upgrading intercooler, even if you do have a stock turbo. Living in texas and the hot temps down here, intercooler upgrade wasn't a bad idea lol.
Old Jun 29, 2012 | 03:24 AM
digitalskillz's Avatar
I think the downsides to running a larger aftermarket IC are that they are heavier, and have just the slightest delay of throttle response as the pressure from the turbo has to shrink down a larger volume of air in the IC before going into the engine.
Both of these downsides are pretty minimal though, and as Kracka said, cooler air is always better. As cooler air=denser air=more explosion=more HP. Also a cool engine is a happy engine.
I don't recommend getting a Perrin IC though as they are 32 LBS, right at the nose of the car no less. Whereas the ETS ones range around 22LBS + or - a few LBS for different sizes. I think stock IC is 12 LBS.
But plan out your parts and $ wisely unless money is no object. An upgraded IC probably isn't "needed" at first.
An IC isn't going to "make" power per se, just fix a problem. Heat.
Old Jun 29, 2012 | 07:04 AM
Alpha X's Avatar
Im still on the stock turbo but upgraded the entire intercooler piping and fmic. Give ETS a call
Old Jun 29, 2012 | 07:38 AM
dyss.'s Avatar
FMIC is my next updrade
Old Jun 29, 2012 | 08:06 AM
Kracka's Avatar
Not true, I personally weighed one that I helped a neighbor install and it was 22 lbs.
its2ply
Apr 28, 2015 03:25 AM
steven121
Dec 15, 2013 02:32 AM
Jcusco407
Sep 16, 2009 04:20 PM
funnyclub
Jul 6, 2007 09:18 AM
ralliartboy9889
14
Feb 12, 2007 10:44 AM
