Sponsored by:
Sponsored by: CARiD
Weird idle and rpm bounce
Old Sep 17, 2012 | 08:07 AM
starkx2's Avatar
Can a tune cause the idle to be higher than normal (assuming around 600rpm or so). I am currently bouncing between 1k and 1200rpm with most of the time around 1k. Also, when given little throttle to about 2k-2300rpm it takes about 7 secs or so to return to idle (1k). If it helps there don't appear to be any leaks.
Old Sep 17, 2012 | 08:15 AM
Montini06's Avatar
Did you do a BLT?
Old Sep 17, 2012 | 08:39 AM
Veronica's Avatar
Is it a rythmic 'hunting' of idle dips - revs... dips revs...?
If so - that is a vacuum leak.
Old Sep 17, 2012 | 10:59 AM
starkx2's Avatar
No idle dips.. Idle raise yes but then it returns to the its normal idle of 1k
Posted from Evolutionm.net App for Android
Old Sep 17, 2012 | 11:01 AM
hackerrei's Avatar
I had the same issue with a tune.
When I rolled up to a stop with the clutch pressed in it would bounce up and down a few times then be at a little higher then normal RPM.
When I changed to a different tune it went away but I would not rule out getting a smoke test done just to be safe.
Old Sep 17, 2012 | 11:31 AM
starkx2's Avatar
That's exactly what it does.. Testing will be done within the next few days
Old Sep 29, 2012 | 05:03 PM
fnlygotboost's Avatar
had the same issue, smoke test and there was leak near my BOV
Old Oct 3, 2012 | 05:20 PM
4ever Boosted's Avatar
Sounds like a BOV issue to me.
Old Oct 4, 2012 | 05:45 AM
Get Rad's Avatar
Did you check the FPR hose?
Old Oct 11, 2012 | 02:28 PM
Gstv's Avatar
Had the same issue being stock I took it to the dealer they said the throttle had carbon build up they cleaned it and my car was like new again they also reflashed my ecu
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Drsous
May 1, 2016 05:47 PM
Stubbie68
Jun 29, 2015 03:45 PM
Isamu966
Aug 14, 2013 01:23 PM
kaymin
Jan 17, 2011 05:12 PM
