Sponsored by:
Sponsored by: CARiD
What is the best year to buy a Evo X
Old Dec 8, 2012 | 02:44 PM
  #46
TheBlade's Avatar
Originally Posted by migs647
They're the best to tune, as in get the most power. The 2012s are having issues with making power (possibly cams, TBD by GSC). 2013s don't have enough info.
Tephra has a beta for the 2011s and 2012s that is currently being tested. Should be out soon.
I've been following the news. Can't wait
If it helps the OP though, I haven't had any problems with '11. So far 20k miles in 15months.
Old Dec 9, 2012 | 07:19 PM
  #47
vtecless's Avatar
i would say 2010 so you can still switch tuned maps on the fly, can't do it with 2011-2013
Old Dec 10, 2012 | 11:50 AM
  #48
JonGonzo's Avatar
I bought a new 2011 mr it was good but I missed manual shifting. When I did a couple of back to back pulls the tranny overheating light came on. So I don't see how people with MR's making decent power don't have tranny problems when mine would overheat with no mods. I ended up trading it in for a new 2011 gsr and I couldn't be happier. Don't forget to change out the relays, mine were junk within 2,000 miles. That's probably why your 2013 falls on its face past 5k.
Old Dec 10, 2012 | 08:07 PM
  #49
Risky Guy's Avatar
Originally Posted by Supraboy1
The MR will absolutely hold more than 400 HP and 400 TQ. I have done it and there are others as well, daily driving reliable. Also there are good things soon to be announced. Don't listen to the nah-Sayers who say it cant be done.
Thank you for that info,im starting to feel better that I did go for the MR.
I wish I could have grabbed the 5 speed, but was rear ended in a car wreck & had spinal fusion on my neck & pain is really bad,plus a torn acl right knee when i was 17.
Just cant have the fun I used to.
One of my favorites was high speed roaller coasters.
Ill trade for a car this is quick even though 400/400 is my end goal.
Im not even close to that now.
right now im only 296whp/292tq Its gonna take me a while to get to that level.
Just a tune & a drop in k&n.
Just have the concern about long term.
Old Dec 10, 2012 | 08:38 PM
  #50
BlueFish's Avatar
I have a 2012 MR which I got new in July. I have a little over 6k miles and I just had a weard issue with it. It is at the dealer and they are doing a warranty repair.
From what I was told, one of the coil packs was melting due to higher voltage coming out of the ECU.
I hope they fix the issue soon.
Old Dec 11, 2012 | 05:23 AM
  #51
Sunwalker12's Avatar
I thought this issue was fixed for the 2011s and up....guess I'll have to swap mine out with the DRL one and see if it makes a difference. Scary thought with the possible lean out conditions lol
Old Dec 11, 2012 | 07:24 AM
  #52
Macky's Avatar
to the best of my knowledge Mitsu isnt changing them from the factory. I know Road Race Engineering changes them for you when you have them tune your car here. I dont know if tuners across the country do the same.
Old Dec 11, 2012 | 08:48 AM
  #53
That's good info man...so swapping the relays between the fuel and DRL is a known fix but is it a permanent solution or is an upgraded relay a must?
Old Dec 11, 2012 | 05:17 PM
  #54
migs647's Avatar
Either something was wrong or your car was in some intense heat. Guys do multiple pulls all the time.
Old Dec 11, 2012 | 07:26 PM
  #55
mixlplix's Avatar
Originally Posted by meltdown
I did get the '13 GSR.... kinda wish I held out for an MR though for a DD.
Man they fall so flat above 5k rmp. It needs a tune bad. I miss being able to pull hard to redline.
i noticed the 5k fall during my circuit drives...i did a drop in filter and it really woke up after 5k...amazing how the ecu responded
Old Dec 11, 2012 | 09:28 PM
  #56
Windforce18's Avatar
I have a 2012 and I was really surprised by the numbers I made. I have seen some of the 2012's make low numbers in the dyno section though.
I'd recommend 2011+ because of the little improvements they made over the years (mainly the timing chain for me).
Old Dec 12, 2012 | 08:36 PM
  #57
JonGonzo's Avatar
I don't know it was only 70 degrees out. I'm glad to hear that other mr's can take some abuse.
Old Dec 12, 2012 | 08:40 PM
  #58
JonGonzo's Avatar
I ordered my relay kit from South Side Performance. They have the new black relays, as far as I know those are the latest and greatest.
Old Dec 12, 2012 | 09:25 PM
  #59
migs647's Avatar
Yah, I had an 08 MR... it killed it at the track (road course). I actually never had 1 overheat, but I also changed my fluid / filter early and had fog light delete kit installed.
Old Dec 19, 2012 | 09:04 PM
  #60
CainEvoX's Avatar
my father always told me to stay away from the first year of any generation if car. too many bugs to work out
Posted from Evolutionm.net App for Android
