Sponsored by:
Sponsored by: CARiD
Ultimate Racing Cat Back Install
Old Oct 1, 2012 | 09:30 AM
Uscbryan's Avatar
I did some research on this but the thread is from 2009. Not sure if the design of the exhaust or Evo has changed any since then. I ordered that catback for now and should have it this friday. Has anyone recently installed it on a 2012 Evo? I read the other thread that said he had to cut the heat shield. Is this something that is still an issue? Any other advice would be great as well. I am sure I can figure it out but any tips or tricks to making it easier would be greatly appreciated.
Thanks
Old Oct 1, 2012 | 10:52 AM
xTiCkxMYxLaInTx's Avatar
As long as the flanges match you shouldn't have a problem. Exhaust will attach right after your heat shield... not sure why he had to cut his?
Old Oct 1, 2012 | 02:31 PM
Gar2212's Avatar
I had the same issue with my Invidia q300 exhaust. the heatshield extends just past the flange so i was having a hard time getting the gasket and exhaust to line up to the cat. You may have to cut/bend or just take off the heat shield around that section in order to get it to fit. I have a 2011 GSR so it may be completely different for you i couldnt tell you.
Old Oct 1, 2012 | 06:46 PM
Uscbryan's Avatar
Thanks guys. I guess I will have to wait and see. Sucks, thought I ordered it in time to get in Friday but it may be Monday. That is going to be torture having to look at it until the next weekend. Maybe I am odd but that is going to be really tough.
Old Oct 1, 2012 | 07:40 PM
mlouis's Avatar
I tried installing my mxp exhaust a week ago and the heat shield was a problem, if the piping is 3 inches then you will have to modify the heat shield. I'm taking mine to a shop that can properly modify the heat shield so there is no vibration.
AllDayAnthony
Feb 15, 2015 05:32 PM
kasaiyoshi
Jun 2, 2014 09:20 AM
wd_cross
Sep 5, 2009 06:08 PM
DC_TypeR
Dec 28, 2008 05:13 PM
