test pipe rattling...
i need some help...i ran out of ideas on what to do....i have 2010 evo x...with greddy shorty dp, ap catless tp with a cnt version rs & torque solution hangers,intake, n uicp....(akuma tuned)my issue is that for some reason after i have done the exhaust...the test pipe section where it connects to the rear section rattles n shakes causing it to knock on the heatshield n on to the bottom of the car...i cant seem to figure out what is left to do...my mech has literally rearrange the whole exhaust hangers on the car to lower the exhaust system keeping it away from the body of the car...that helped alittle but after idling for awhile it comes back nonstop until i step on the pedal then it will be back to normal then after idling again the noise comes back...driving me insane...everyone looks at the car making hoopdee noises (quite embarrassing) it has come down to the point where im thinking is it because of the test pipe being straight n not having that little bend like the stock one would or is it something else??
please help...thinking about going back to stock exhaust...but i dont know if it would hurt cause i got a dyno tune...and suggestions on what i need to do next or options would be??
thanks guys..
imma make a video of it within these few days so you guys would have an idea of it..
thanks guys..
It sounds like you know exactly what's going on. I might put some chalk or orange paint or something on the heat shield to identify exactly where it is hitting and then bend or cut away that piece. Let it idle, get it to rattle, and then see where it touches (if you can't tell exactly now).
The point is, and you know this already, just trying to rearrange the pipe hangers, or push things out of the way temporarily is not going to work.
well i just ordered a new pipe that has the little bend like stock...hopefully this will fix it...n i cant bend it aymore further down...i kno where its hittin...right under the shifter...i even took out that bracket cause there was a metal rubbing noise...so its to me it sounds kinda servere
GinNBoost
32
Jul 4, 2008 08:11 PM
