Sponsored by:
Sponsored by: CARiD
Downshifting
Old Oct 10, 2012 | 03:04 PM
khmerguyx's Avatar
Downshifting
Hey guys of course you can tell Im a noob but when you downshift do you give it a little gas as you downshift or put it in to gear first then gas?
Also what is an unsafe RPM to down shift from?
Sorry I forgot to add. For racing not DD
Thank you
Old Oct 10, 2012 | 03:19 PM
Dirty Dave's Avatar
I speed match when I down shift. Idk I think it might just be a preference?
Old Oct 10, 2012 | 03:22 PM
khmerguyx's Avatar
Old Oct 10, 2012 | 03:25 PM
ImEv0's Avatar
downshift sequence:
-clutch in
-drop gear
-tap the gas (rev-match)
-release clutch
-pedal to the metal/carpet
if you're racing, you want to downshift at a point in your rpm where you wont be hitting redline/limiter. with the amount of tq this car has, you shouldn't have to downshift unless you're below 3.5k rpm or you're on 4th/5th gear. but i dont race/compete so take this with a grain of salt.
Old Oct 10, 2012 | 04:00 PM
TheBlade's Avatar
DownShifting? Never heard of it....
Old Oct 10, 2012 | 04:09 PM
ImEv0's Avatar
its not a preference. its a matter of your synchros going out on you prematurely. when you downshift without rev matching, you're putting unnecessary stress on the tranny.
Old Oct 10, 2012 | 08:51 PM
mp72's Avatar
According to the meme thread, you're supposed to downshift when you are next to a Toyota Prius.
Old Oct 10, 2012 | 09:09 PM
PatricksEvilEvo's Avatar
Correct.
Rev match when you can but hard braking I slip the clutch. Either way just do it smoothly.
Old Oct 10, 2012 | 09:11 PM
davey111483's Avatar
step on the brake, then clutch, drop gear while rev-matching (heel-toe), release the clutch then gas all the way.
Old Oct 10, 2012 | 11:16 PM
mp72's Avatar
How do you heel-toe in an X? It is impossible in my experience. I rev match when downshifting, but heel toe is something that I can't do in my car.
Old Oct 11, 2012 | 02:36 AM
yoshe200's Avatar
double clutch downshifting
Old Oct 11, 2012 | 02:46 AM
k_sheanh91's Avatar
so you press the clutch, put the car in neutral, release the clutch, then you press the clutch again to put it into the gear you're downshifting into? Your calves must be beast mode.
Old Oct 11, 2012 | 04:33 AM
Robevo RS's Avatar
Our transmissions are syncronized. Just shift down when its neccesery.
there is no reason to rev match the transmission in the evo, that is a reason why its syncronized for gear selecting. Hence you can get " locked" out.
Many many people.actually does run slower times on tracks because they pay too much attantion on the rev matching.
Rob
Old Oct 11, 2012 | 04:39 AM
Robevo RS's Avatar
Originally Posted by ImEv0
downshift sequence:
-clutch in
-drop gear
-release clutch
Clutch in
Tap the gas(rev match)
Drop the gear
release the clutch
Pedal to the metal/carpet.
The right order.
Old Oct 11, 2012 | 04:45 AM
Robevo RS's Avatar
No you are not. The stock transmission works with syncros. The name alone explains itself.
I do rev matching to keep the car balanced before or in the turns if its neccesery. Other words keep the car attitude on the smooth side.
