Downshifting
Here's an example of what it looks like when you've practiced (skip to 0:37 for just the downshifts):
http://youtu.be/j1JIf-dqO4I?t=37s
here it how is done
The guy who invented left foot brake on Turbo cars against turbo lag. So basically the "Master":
http://www.youtube.com/watch?v=DbU4GZkt7ig
This x10000. This isn't rocket science. You won't magically get it perfectly after 2 attempts. Practice makes perfect.
Nothing wrong with a X pedal position. It is just as easy to do a pedal work on it as it was with the older versions.
and this i show i am using the pedals, no crazy sized extra plates etc. If you must , put some washers under the gas pedal assembly to raise it closer to you. I dont think it will change anything though with a stock brake set up with the brake booster .
The evo 8/9 with pedal pads is only slightly closer together than the x. I don't have issues with heel and toe on either car. That driver just made it look easy.
Disagree, we didn't raise the pedal but did screw aftermarket aluminum plates to close the gap somewhat. It took about 20 minutes.
