Sponsored by:
Sponsored by: CARiD
WW paint, I got an issue...
Old Oct 17, 2012 | 11:43 AM
SOUL STEALER's Avatar
Anyone else see stains in your paint? My car runs hella rich, so the trunk is black. When I wash the X I see stains from the rich spots in my paint? Anyone else? I'm gonna try polishing one of these days but time...
Old Oct 17, 2012 | 11:44 AM
SD_Lurker's Avatar
yellow spots?
Old Oct 17, 2012 | 11:46 AM
More like a darkening of the white. Its not so bad unless you look at the hood afterwards, and get blinded by that white.
Old Oct 17, 2012 | 11:49 AM
careed's Avatar
I have that same problem only I have a RR evo. The best thing i have found is to clay the stained spots.
Old Oct 17, 2012 | 11:50 AM
Kracka's Avatar
Get some cleaner wax or rubbing compound, it should bring your paint back to snow white. With the right product and a little elbow grease I can even get my exhaust tips looking brand new.
Old Oct 17, 2012 | 11:56 AM
ogrenator's Avatar
Yeah Ive started washing my car once a week to prevent this...we will see how it looks after this winter...
Old Oct 17, 2012 | 12:07 PM
Kracka's Avatar
A quick spray-detailer'ing between washes will help keep it looking good.
Old Oct 17, 2012 | 01:08 PM
denlin68's Avatar
i would recommend 1) clay the car 2) add a layer of sealant which gives u so much more protection than wax and make it harder for conaminates to stick to the back trunk
Old Oct 17, 2012 | 03:41 PM
SpardaVR4's Avatar
While clay barring is a good recommendation, your suggestion of Sealant > Wax is not true.
Both have their unique qualities, but one isn't going to give you more protection than the other.
If you are seeing darkening of your paint I would do the following:
Strip any wax left over on your car (use Dawn or use Chemical Guys Citrus Wash Clear).
Then Spray your car with IronX. It will smell horrible, but most likely your paint has large deposits of iron stuck to the paint.
Wash off with water and then clay bar.
If you want a really good prep job, proceed to polish the car with the lightest polish you have and work your way up from that if needed.
Lay down a layer of sealant, wait 12 hours and lay down a coat of your favorite wax.
Old Oct 17, 2012 | 03:48 PM
dek0026's Avatar
I use bug and tar after each track event and it works very well and no need for much elbow grease. pictures don't do it justice.
Old Oct 17, 2012 | 04:28 PM
Panda_stunter's Avatar
That's how my trunk looks like after 4 days! I just wash it off. But I'm gonna clay bar it really soon.
Old Oct 17, 2012 | 04:56 PM
S2K2EVO's Avatar
[QUOTE=Kracka;10458862]Get some cleaner wax or rubbing compound, it should bring your paint back to snow white. With the right product and a little elbow grease I can even get my exhaust tips looking brand new.
[/QUOTE
Would that Wax be good to get some surface scratches on the top of the door handle from a ring? If that is a cleaner/cutting type wax I would think that would work.
Old Oct 17, 2012 | 05:29 PM
SpardaVR4's Avatar
A wax has no surface cutting abilities as they contain no abrasives.
You might want to look into an all-in-one that contains light abrasives and some polymers like that in a sealant.
If you want to go traditional, I would use a light cutting polish. Menzerna is the best I've used. Then put on a layer of wax/sealant on top to protect the freshly polished area.
Gstv
Evo X How Tos / Installations
19
Jul 11, 2017 09:59 PM
free ride
Jul 7, 2014 08:41 PM
zupber4930
Mar 17, 2004 12:44 PM
wags528
Feb 17, 2004 07:25 PM
Jonasan50
May 21, 2003 06:31 PM
