Evo X RS fume smell in car
It stops crap and fumes coming into the car. but if you have a sub, allows for air movement. I think its just got a couple of rubber flaps or something
I know that in the IX's when you pull out the cheap paneling in the trunk and look down in the sides between the outerfender and where it attached in the trunk (where most people put methanol tanks) you can see a little flapper door that goes VTA.
I dont know much about the X's but you should check this out. One might have gotten stuck open if the X's have them.
I would take a pic of what I'm talking about but I am at my old house packing gettting ready to move into a new place this weekend if I remember I will.
So here are the pics I said I would get for you. I forgot how incredibly easy they open, you literally barely have to touch them and it opens so if you have a sub pushing air around I would say that is the culprit and why you are smelling exhaust in the cabin.
What it looks like when you pull the paneling away
How the vent opens
What it looks like when shut
How the vent opens
I'm not 100% sure and I'm just throwing this out there but does the RS use a bigger fuel pump? My buddy has an S13 with a Walbro 255lph and you smell that thing and hear it more than a stock pump as well. Just a little bit of info I had lying around in my brain bank, let me know if it helps
Renato
Team TWM Performance
Renato
Renato
Renato
Honestly I don't think that a higher capacity fuel pump would cause a smell especially if it's in the tank. I put a 255lph walbro in my S14 and it did not smell like gas when everything got plugged back up and sealed.
I think the OP is having issues with smelling exhaust fumes in his car not fuel right?
I'd like to get down to the bottom of it if possible. Maybe you have a small exhaust leak the comes into the cabin through those breathers in the boot somehow :SRenato
Also you might want to (if you don't have one already) upgrade your exhaust system to a single out which dumps out to the right of the car. If the breather is where the sub is that should put your exhaust gasses floating up and to the opposite side of the trunk.
if you get one that sticks out just a tad from the diffuser you should be able to clear the trunk area no problem given that heat rises.
Renato
You might want to look in here for inspiration.
https://www.evolutionm.net/forums/ev...st-thread.html
To really show what I suggested have a look at the JIC Spartan DE Type 1. Single outlet to the right and clears the diffuser completely.
There are plenty of exhaust systems on that thread that don't even make it half way out the diffuser those are definitely a problem for fumes and partially for drone too.
kevzxvii
Dec 3, 2015 04:57 AM
jdm4g63tgalant
Apr 2, 2005 12:37 PM
