Evo X RS fume smell in car
Ive read a couple of threads on this forum and found out that there should be some sort of breather behind the subwoofer on the gsr models.
My X RS doesn't have this and there is the big gaping hole to the outside.
Does anyone have a picture of said valve so i know what one should look like, and also is this likely to solve my cabin fume problem?
May be a dumb question but are you running cats at all? Cars that have all cats remove tend to smell a bit even with windows up.
Also have you done any exhaust work and possibly may have created a leak in the process?
The stock exhaust location should allow for hot exhaust fumes to flow behind the car and up when moving or are still for brief periods of time are you in heavy traffic often?
It has an aftermarket exhaust also but there are no leaks.
It only smells when im on boost with the windows down, but it doesn't smell like its coming in through the window.
I was wondering if by having the window down, it creates a vacuum in the car and sucks vapour in from the boot, or am i way off here?
Not sure but try this it's a technique I learned for sucking out mosquitoes in Galveston so should work for fumes.
Drive around with the front windows cracked a little bit that should create a bit of a vacuum behind you and pull in cool and fresh air. If the smell goes away then fumes are getting in the car. Not sure how the RS is laid out we don't have those here (I'm curious on the specs though) so I can't tell you. Does it still have factory carpeting especially in non essential areas like the trunk?
FYI, the RS has a manual 5 speed and a steel rear diff. No AYC but it has the ACD. It doesn't have ABS or any of that, and it doesn't have air con. There are other mods too compared to the GSR models
Ill try your idea
So, close it up you think?
NICE!!! AP brakes huh?
But no good on the steering wheel location. Best way to get run over by a bus in Houston Tx.
Still saying running HFC (the really flowy kinds) and worse No CATs will give your fumes a smell. If ever drive behind someone who is running a car HARD you'll smell something like rotten eggs. It gets worse, much worse, without cats and without having to run the car too hard.
