Sponsored by:
Sponsored by: CARiD
I have no choice but to put Regular gas!!
Old Nov 5, 2012 | 07:45 AM
ugakirk's Avatar
Never go in to boost.
On a side note, I thought that if you are tuned, the ECU will not change the maps for lower grades of gas automatically. I don't know for sure, but that's what I thought.
And like others said, Even when you get 93 again, stay out of boost. You will need to make sure it is all gone..
Old Nov 5, 2012 | 08:31 AM
AIM WO4's Avatar
You'll know if it's bad... When you turn off the car, and the engine keeps going...
Old Nov 5, 2012 | 08:57 AM
EvoForumUser12's Avatar
Ah yes - decoking an engine. That takes me back. My R5 GTT needed it twice before finally detonating itself into oblivion.
Old Nov 5, 2012 | 09:14 AM
gsrboi80's Avatar
It will if your tuner was worth a spit and didn't make the Low Octane Fuel and Ignition Maps the same as the High maps
You'll be ok just dont beat it. Had to put 87 in the Misses FXT too. It sucks
Old Nov 6, 2012 | 10:37 AM
Shig's Avatar
Slow Fast
Originally Posted by HAHAV8
It will be okay.
Just BABY IT! I mean no boost, too bad if the people behind you don't like that you are going slow.
Just granny it along. As long as you aren't boosting it will be alright.
Slow fast cars are cool
ever see that super exotic car just cruising around?
Old Nov 6, 2012 | 03:01 PM
Metall1ca's Avatar
Had to do the same today. Sigh.
Old Nov 6, 2012 | 07:48 PM
kahuna001's Avatar
had to do the same a couple days ago.. Then a couple hours later i found a BP with premium..
Old Nov 6, 2012 | 08:04 PM
SSickLS1's Avatar
lucky me, all my cars take premium...ive been trying not to drive unless really needed. but everyones got the right story..take it easy and youll be fine
Old Nov 6, 2012 | 11:50 PM
aboogabooga's Avatar
This **** is a lot harder than I thought, not to boosting !!! Now my boost gauage is well worth spend $$$$ . Again thanks everyone for ur info!! Ans just to update, still, only Regular gas available in NYC.. "50 mph on highway FTW"
Old Nov 7, 2012 | 12:10 AM
XTR Performance's Avatar
Same with us. I just found some gas tonight on Route 46 BP Gas Station with super . Previously I went to 4 other stations that either had no gas or only had regular. It's a nightmare out there. Everyone stay safe!
Old Nov 7, 2012 | 05:22 AM
Panda_stunter's Avatar
The car has 2 maps stock. Hi-octane (93 or 91 depending on the area of purchase, in this case urs is 93), and low octane maps. Low octane map just make ur car tune richer. So it's ok if u put regular since the ecu will determine it. Timing will stay the same, but u will be filling up more since ur car will be running rich...and I'm not talking about 10afr rich, I'm talking about 8afr rich...diesel engine style!
Old Nov 7, 2012 | 12:50 PM
I NEED BOOST's Avatar
I'm in the same boat. Had to put in 87. Got down to just below half a tank and put in 93 with octane booster. I havent seen boost in Almost 2 weeks! Cars running fine. Once this tank is empty I'm gonna fill up with 93 again and add another bottle of octane booster
Old Nov 7, 2012 | 04:13 PM
Nickzorz91's Avatar
Better to run race gas or 87 octane? Lol.. my dad has some race gas for his drag car lying around and the gas stations have no premium still
Old Nov 7, 2012 | 04:37 PM
04Evo851374's Avatar
Don't worry buddy I'm in the same boat
Old Nov 7, 2012 | 04:47 PM
Raptord's Avatar
Even if the tuner was careless and made the high/low octane maps the same, the ECU will still pull timing and richen the AF mixture when it detects knock as a short-term correction. The issue with both maps being the same is that there will be no long-term correction to timing and fuel as the octane level in the ECU gets lowered by repeated knocking.
On pre-X ECU's, low-octane maps have lower timing, not just richer AF. I would imagine this is the same on the X.
