Sponsored by:
Sponsored by: CARiD
Need help!
Old Nov 14, 2012 | 09:48 AM
DevilDog7's Avatar
Need help!
Just got my 2.2 motor back and getting it in. Stock turbo is going on it till its broke in then will be putting on the ef4 and getting the final tune. Is there only 3 Lines on the turbo? The two oil lines and the water return line? We have three lines on and have one open port where were assuming another line should go. Anybody with information? Thanks
Old Nov 14, 2012 | 10:14 AM
ChrisCarey's Avatar
Water feed and return sir, you're missing one.
Old Nov 14, 2012 | 10:38 AM
DevilDog7's Avatar
we only found three. not sure if one is still connected in the car. Trying to figure out where they all run to so i can trace it back.
Old Nov 14, 2012 | 10:39 AM
DevilDog7's Avatar
are they all bango bolts? Or are three lines with banjo bolts and one with a different end?
Old Nov 14, 2012 | 10:58 AM
Kracka's Avatar
Both coolant and oil-feed are bango, oil drain is a 2-bolt flange.
Old Nov 14, 2012 | 11:39 AM
DevilDog7's Avatar
the oil return line is different. then theres the oil fee and water feed line that i see with banjo bolts. is the water return also a banjo?
Old Nov 14, 2012 | 11:57 AM
Kracka's Avatar
Yes.
Old Nov 16, 2012 | 07:28 AM
DevilDog7's Avatar
Im missing the water return line. Any idea as to where that line runs to?
WRC-LVR
105
Jul 28, 2017 09:39 AM
GreenAWD
Jul 28, 2012 04:57 AM
Tiresomejunk
May 25, 2012 06:21 AM
sk8terdude929
Oct 31, 2011 03:39 PM
ryukinevo
Oct 18, 2010 07:30 PM
