Sponsored by:
Sponsored by: CARiD
4WD system service required?!
Old Oct 13, 2014 | 10:02 AM
  #31
LB_Reddy's Avatar
I would get it diagnos asap if still warranty.Mine does on a very cold morning drive was it show up warning"possible Ices".
Old Oct 13, 2014 | 02:41 PM
  #32
Iowa999's Avatar
Originally Posted by GetterDragun
I had the dealer change it as per the recommendation of the manual. Figured this was preventative maintenance for such things!
Were you able to figure out how to relocate the AYC pump?
I know that it's a year later, but sometimes real life puts car stuff on hold.
I had my pump relocated by two guys in Racine, Wisconsin. They did a fantastic job, let me help and learn, and were hilarious the entire time (a la Click and Clack). I drove 4.5 hours each way for this and would say that it was worth at least 6 hours each way for the peace of mind and good work.
So nice to have S-AWC again (after more than a year), but I did learn a bit driving with two open diffs.
Old Oct 13, 2014 | 04:09 PM
  #33
elkazX's Avatar
so my 4wd system service light is also on and has been on for a while. Is my ayc pump done for? I have a 12 gsr with 28k miles, and i'm not sure if it would be covered by my warranty.
Old Oct 13, 2014 | 05:30 PM
  #34
Iowa999's Avatar
Should be covered, but, in case you're in the east side of the state, don't go to Zimmerman. Go anywhere else. Anywhere.
Old Oct 13, 2014 | 05:33 PM
  #35
elkazX's Avatar
nope im down in des moines. Thanks for the heads up tho
Old Oct 15, 2014 | 09:51 AM
  #36
wez's Avatar
wez
4wd service sys. req. keeps coming on/off
Why does my 4wd ssr light come on and then dissappear. Today it was raining pretty heavily and I was driving in this and then boooom it came on and then it went off and then it came on and then off n again...though it doesn't stay on but why is this?
Please help
Old Oct 15, 2014 | 11:33 AM
  #37
Iowa999's Avatar
When a pump starts to die, sometimes it makes pressures within the time limit; sometimes it doesn't.
Old Oct 16, 2014 | 03:03 AM
  #38
wez's Avatar
wez
Thanks a lot bro
so If and when the pump dies...can I still drive or should I park the car till its fixed and limit the driving?
Old Oct 17, 2014 | 07:54 AM
  #39
Iowa999's Avatar
Yes, you can drive with a dead pump. I did so for more than a year. Just pull the power to the motor, in case the motor can be saved.
Old Oct 18, 2014 | 07:34 AM
  #40
wez's Avatar
wez
So the 4wd n ASC ssr indicator came back on... so if I disconnect it, will the indicator still he showing up?..really don't want tto damage the car till I get the part. And my front struts are really bad and making noises while I drive, could that be a reason why this is going off?
Old Oct 18, 2014 | 09:12 PM
  #41
Iowa999's Avatar
I doubt they're related in any way other than being two parts of a Mitsubishi.
Cut the power to the pump to save the motor. Yes, you'll have the warning all the time until you fix it. (You get used to it after a few months....)
Old Oct 19, 2014 | 03:18 AM
  #42
wez's Avatar
wez
Haha!..thanks ALOT for your help bro...I just ordered a set of FA500 coil overs ...so I gotta stack up again to get this pump. ..so I guess so more having fun with this car till the pump is fixed huh..damn ...lol
Old Oct 30, 2014 | 09:08 AM
  #43
Mystykalbaby's Avatar
OP i had the flat tire every day thing going on and it ended up being a hair line crack in the side of the threads for the tpms sensor.
Hope that helps the one issue.
Old Nov 2, 2014 | 01:39 AM
  #44
fandadar's Avatar
I have ASC/ABS and 4WD lights all on, turns out to be rear hydraulic unit w/e that is and bad ABS sensor
Old Nov 2, 2014 | 01:06 PM
  #45
Alpha X's Avatar
Same thing happened on my car about a week ago. Got it fixed by Mitsubishi and it turned out to be a bad wheel speed sensor.
They also did the recall.
