Help me!!! Service light.
Well the dang light is back and will not go away now even on sunny days with no snow the light is on idk what to do both the dealer ship that are in Utah suck ***** so idk what to do with my car any suggestions?????
After my dyno tune, if I floor the car fast, the engine light comes on. It's because the original setting wasn't meant to handle such power. So i eventually learned to gently push the gas pedal. I dont know if this helps but if it's something similar i wouldn't worry about it
You need to get tephra mod. What's happening is when you hit 28-30 boost your cars going into limp mode and cutting ayc off. Tephra will fix this.
The car may not be overboosting. If its tuned for over i believe 28 PSI and the tephra mod is not installed that eliminates this issue of putting your car in limp mode this will continue to happen. I know because it was happening to me after being tuned and i didnt know what the problem was. Took it to ANOTHER tuner a few weeks later, who installed Tephra and the limp mode issue was gone. Sorry i said that wrong i meant the AYC light, not the actual AYC being off lol.
P.S. I had a X back then.
jdmpoirier4
Jan 4, 2012 10:39 AM
dsm25psi
ExtremeTurboSystems.com – WA
88
Aug 17, 2010 04:45 PM
