Sponsored by:
Sponsored by: CARiD
My X is nickel and diming me to DEATH!!!
Old Jan 30, 2013 | 12:20 PM
ugakirk's Avatar
I've never heard of that. Kind of dumb to me..
Old Jan 30, 2013 | 12:31 PM
Kracka's Avatar
Clutch is a wear & tear item, so really all you're looking at is $1,400 in unplanned maintenance over the course of 70k+ miles.
I do agree with AWDTerror, parking in gear puts extra stress on the entire powertrain. Park in neutral, let the powertrain relax, and use the parking brake.
Old Jan 30, 2013 | 12:50 PM
Yoo Shin's Avatar
Add a cmc on the up coming list.
Old Jan 30, 2013 | 01:14 PM
Evostare's Avatar
I just replaced my clutch - totally not looking forward to a cmc replacement
Old Jan 30, 2013 | 01:21 PM
AWDTerror's Avatar
If you can do a clutch job yourself then the CMC won't be that bad.
Old Jan 30, 2013 | 02:32 PM
DropThatHammer's Avatar
Originally Posted by AWDTerror
Most stick the car in 1st or reverse, then let off brake, before setting the handbrake which puts stress on the chain.
Most people let their car roll in gear before they set the emergency brake. It's an old school way of thought, but what happens is that this puts undo stress on the chain because the clutch is engaged and trying to turn the motor. You can actually force your motor to turn over if you are on a steep enough hill.
+1
This explains why you can pop the clutch to start a car. The car is off, clutch pedal is to the floor and the car is in gear. Once you gain enough speed, you release the clutch pedal and apply gas and the car will crank over. It makes perfect sense how it strains your motors supportive components(keeping it in gear parked that is).
CMC is butter on rice, the hardest part (which isn't hard at all with some experience) is bleeding the line.
Old Jan 30, 2013 | 06:34 PM
1FastT2's Avatar
Guys I never leave my car parked in 1st gear or any gear for that matter. I was getting timing errors and had the dealer check things out. They claimed everything was good however when I removed the valve cover the timing chain was out of spec so I had it replaced. It ran like a champ after it was replaced and more more timing CEL's.
Old Jan 31, 2013 | 03:58 AM
TRIO's Avatar
There was a recall or TSB (I cant remember), for the timing chain for '08 EVO's. Got mine done for free at the dealership. Had to drive a crappy rental (a PT Cruiser....don't laugh...) for about a week.
Old Jan 31, 2013 | 04:18 AM
johno's Avatar
Your doing great compared to me i dropped 6000 on my car when i first bought it my evo 8 that is with only 13000 miles on it. Driver before me really sucked at shifting. 1400 is nothing for a performance car. I mean how many sets of tires have u gone through thats prolly more money than all this stuff combined. Also how many times has the car been out of service? I think the evo is treating u great
Old Jan 31, 2013 | 04:46 AM
Scox1026's Avatar
Originally Posted by 1FastT2
Almost sounds like a girl problem but its my car that I so loved thus far.
1st it was the timing chain at 65k miles - $1400 dealer installed
2nd was the clutch at 69k miles - $750 I installed.
3rd was the ACD pump failing - $8, fixed it myself.
This is starting to get rediculous!!! I thought this was going to be a good car, boy was I wrong!!!
$8 acd pump fix is better than the $1900 im about to shell out for a new one
Did you just replace a seal and clean it up? wish i would have thought to rebuild mine before it failed on me...
Old Jan 31, 2013 | 09:19 AM
1FastT2's Avatar
The only thing I needed to buy was a box of M5x85 socket head bolts. My motor froze up on mine. I took it apart, cleaned the brushes put it back together and it works like a champ now. There was no way I was going to spend all that money on a new one. It was definately worth taking apart to see if I could repair it before searching for a new unit.
Old Jan 31, 2013 | 10:19 AM
whiteEvo08Y's Avatar
Wow, Guess i will be putting her in neutral all the time. Thanks for the heads up in.
Old Jan 31, 2013 | 01:06 PM
TheBlade's Avatar
Originally Posted by DropThatHammer
+1
swapping the CMC on a X is a royal PITA. It's much harder than on the 8 and 9. My local shop wont even do a CMC job unless they are doing your clutch at the same time, just because it's easier to get at with the trans out of the way.
Old Jan 31, 2013 | 03:40 PM
love9sick's Avatar
That's not that bad. Only the drive chain seems un-expected. I clicked on this thread expecting a poor individual on his third engine.
Old Feb 1, 2013 | 05:49 AM
Scox1026's Avatar
I may have to try this before i buy a new one, thanks for the info.
