Sponsored by:
Sponsored by: CARiD
service engine light flash sometimes. need help?
Old Feb 26, 2013 | 12:19 PM
david@evo's Avatar
I got evo x, 2011. And get protune from cobb in plano, mods with down pipe, test pipe, EBCS, turbo inlet,SF intake and catback. And I get 320 whp, 340wtq,27psi. Sometimes when push the gas pedal hard the service engine light is flashing and go away. Maybe the sensor is too sensitive or engine was knocked? confuse about it. anyone give some suggest?
Old Feb 26, 2013 | 12:55 PM
Kracka's Avatar
Tephra CEL knock flash; sounds like you're knocking a bit. Are you using quality gas? What fuel were you tuned on?
Old Feb 26, 2013 | 01:50 PM
TheBlade's Avatar
Kracka always knows the answer and can add replies faster than most
Old Feb 27, 2013 | 09:32 AM
david@evo's Avatar
15 knock.
93 octane. shows 15 knock count on access port. anything to concern?
Old Feb 27, 2013 | 10:19 AM
kyoo's Avatar
that's too much
Old Feb 27, 2013 | 10:42 AM
TheBlade's Avatar
Yeah, a couple counts on a pull is okay if it's not consistent. But 15? that's excessive.
Try an octane booster. Maybe you got some bad fuel. Keep your eye on the counts too.
Old Feb 27, 2013 | 11:49 AM
Kracka's Avatar
15 is excessive. What kind of fuel were you tuned on, and what are you running now (octane, brand, and location)?
Old Feb 27, 2013 | 12:18 PM
ugakirk's Avatar
Yea Cobb usually tunes pretty well.. Maybe it was the fuel..
Old Feb 27, 2013 | 12:47 PM
Kracka's Avatar
Agreed. I rarely ever even see 3 counts, which is where my CEL flash is set at.
Old Feb 27, 2013 | 01:28 PM
ugakirk's Avatar
Could his fuel pump relay be going bad and he's not getting enough fuel at WOT maybe?
Old Feb 27, 2013 | 01:40 PM
Kracka's Avatar
Possible; or his FPR hose popped off.
Old Feb 27, 2013 | 01:50 PM
cdmassee's Avatar
Definitely check the Fuel pump relay! ASAP
switch it with one of these other relays, preferably the headlight high beam relay and see if problem still persists.
Old Feb 27, 2013 | 02:16 PM
TheBlade's Avatar
If it's the relay, he can cross check to see if he's running lean on a WB AFR (If he has one), if he's not showing leaner than tuned, yet knocking, it's probably just octane.
I'm betting bad fuel, but if the OP has an 08-10, changing the relays out is never a bad suggestion
Old Feb 27, 2013 | 05:49 PM
david@evo's Avatar
2-7 knock count
just call calvin at cobb, and sent me a new map. keep a knocking range from 2 to 7 knock count. but almost keep 2 count during accerlerate. is it in the safe range? I just new user, need to learn more. haha thx.
Old Feb 28, 2013 | 09:18 AM
Leezon's Avatar
That still seems a bit strange, you should look into the FPR/fuel system as the others have said.
