Sponsored by:
Sponsored by: CARiD
Water in trunk coming from tail lights?
Old Mar 2, 2013 | 08:09 PM
markpaco's Avatar
I noticed a little bit of water in my spare tire well so I pulled out the trunk trim and found that water was coming in from the outer tail light mounting holes. There are two square push-in fasteners that screws go into. The water leaks in from those openings. I tried changing out the little thin rubber gaskets under the push-in fasteners but it still leaks.
Does anyone have any similar experiences/solutions?
Old Mar 2, 2013 | 08:24 PM
Thomar's Avatar
This is on the evo, or your lancer ES?
Old Mar 2, 2013 | 09:22 PM
ikt's Avatar
ikt
there's a foam gasket behind the tail light, make sure that's intake. You can put some gasket maker stuff (RTV) on the tail light tab in the area where the two screw holes are so it seals the wholes. Alternately, you could put a rubber washer behind the screws as well.
Old Mar 3, 2013 | 06:25 PM
gabesir's Avatar
I think your blinker fluid is leaking. must take it in to service ASAP before you run out.
markpaco
Evo X How Tos / Installations
39
Apr 4, 2025 09:33 PM
Sideck
Dec 24, 2018 08:50 AM
ExViTermini
10
Jun 20, 2014 06:03 PM
vitamin ek2
For Sale - Cars For Sale
17
Jul 24, 2013 10:34 AM
