Sponsored by:
Sponsored by: CARiD
Evo rough idling after installing intake.
Old Mar 26, 2013 | 06:09 PM
arievox's Avatar
Hey everyone!
Was hoping I could get some insight on the rough idling issue I'm having with my car right now.
When I first purchased the car, not too long ago, it was rough idling badly. Bouncing between 500-2000 rpms. Realized the vacuum line had split and I replaced it and it's been fine ever since.
I recently bought a new ETS intake and installed it on my car earlier last week. Just today while I was at a stop sign it started rough idling badly. I checked the vac lines and they were fine. Was wondering if anyone on here had a idea of what it could be?? Any ideas would be appreciated!
Old Mar 26, 2013 | 07:00 PM
SpardaVR4's Avatar
Do you have a heat shield in place? Check your fuel pump relay too.
Old Mar 26, 2013 | 11:39 PM
J Yim's Avatar
Was your AC/Heater on?
You most likely will need a heat shield. The fans in the front of your car is messing with the MAF through the exposed cone filter.
Its a common issue with open element filters.
Old Mar 27, 2013 | 04:37 AM
evokid4life's Avatar
Originally Posted by arievox
Hey everyone!
Are you still using the stock maf housing?
Old Mar 27, 2013 | 06:19 AM
rkelley's Avatar
+1 May need MAF scaling if not
Old Mar 27, 2013 | 07:13 AM
arievox's Avatar
Heat shield isn't in place. I know its dumb. I'm going to put it in today after I get off work. The AC was on. But even after I turned it off it was still bouncing irratically.
Old Mar 27, 2013 | 07:48 AM
Kracka's Avatar
Try resetting the ECU and let it relearn it's parameters.
Old Mar 27, 2013 | 08:58 PM
prowakeskater's Avatar
what size is that intake? You may wanna go ahead and tune that beezy
reset the ecu by pulling the negative off the battery and turning the key
Old Mar 27, 2013 | 11:31 PM
1012Xmr's Avatar
Recheck your vacuum lines had same prob mine was split a the bov on the back by the connection didn't see it at first
Old Apr 3, 2013 | 03:16 PM
SUBIIKLR21's Avatar
May need a tune to adjust maf settings.
Old Apr 4, 2013 | 09:20 AM
panamah_r3d's Avatar
Mine used to do that pretty often until I put the heat sheild on. I rarely have it happen since then.
Old Apr 4, 2013 | 09:41 AM
Jerm6908's Avatar
I have this issue with the cobb SF intake i see people rigging up their own heat shields but i want cobb to make one!!
Old Apr 23, 2013 | 09:24 AM
Zbrit00x's Avatar
Check for leaks, scale the maf, after all that and issue persists you may need an air straightener of some kind
Old Apr 23, 2013 | 12:53 PM
AGinHD's Avatar
Doesnt the ETS intake come with the heatshield?
Old May 4, 2013 | 07:38 PM
w3ty3t10's Avatar
i suggest getting a tune.
1)tune
2)heatshield
3)fuel pump relay upgrade [i use ams]
4)for hose check up and tip tie
5)connectors for intake and clamps
