Need Feedback on aftermarket CMC, Yes another victim
The Magnus Kit I purchased installed nicely.
There are a couple things you need to do that aren't on the install instructions. But overall it went on nicely and the clutch feels only a tad stiffer.
My cmc blew on the highway, thankfully I was in traffic and had enough speed to roll onto the shoulder. What's the install time generally run for a shop on this? My Evo was towed under warranty to the nearest mitsu dealer, which is unfortunately over 100miles from where I live.
Not trying to thread jack, just looking for input on # of hours since many are talking about the difficulty of the install.
Thanks
I'm hoping to be covered under warranty, but will have to wait til later today. We shall see =/
Thanks
I'm about to buy a evo x that has already had to have the cmc replaced. It was done under warranty as I understand it but as under warranty just another faulty oem one was put in. I'm interested if this replacement is easy for someone that has limited tools. I'm also interested in estimate time for a shop to do this. I'm close to ams Chicago. Since they also make a replacement I'm very interested in doing this soon. I want to build the evo into the most reliable machine it can be.
As for performing the replacement yourself with limited tools, I wouldn't recommend it unless you have another vehicle that can get you somewhere to buy / find any tools you might be missing.
Good Luck
If they know what they're doing, a shop will charge you at least 4, if not 6 hours for the work. It's fairly involved to install the replacement CMC Kit. It's not just a 1-for-1 replacement from stock, hence the "kit". If they don't know what they're doing, expect 8-10 hours of labor.
Good Luck
Good Luck
Thanks for the info. I do have a beater DD right now, (dying trans and clutch) which is one of the main reasons i'm trying to get the evo... so as long as it holds out I can drive that to the local harbor freight for tools I dont have.
Can anyone confirm that the posted video is the correct and proper steps? I may just give ams a call and see what they'd quote for the work, they're not far away from me...
go somewhere else. they are either over-charging you for labor, or over-charging for the part (or both) .. stock part is like $2-300 (I can't remember), the upgraded part I bought from MAPerformance was around $290 .. labor @ 2 hours for stock part, or @5-6 hours for aftermarket part at an intelligent shop .. you can do the math on the rest..
Another failure
My CMC went out last Saturday. I bought MAPerformance's CMC and asked the dealership to install which they said they will. But they tripled the labor price after the part came due to it being a kit vice a bolt on replacement so I'm having my X towed to a local shop in town. From what I remember the directions were straight forward but just tedious.
