Sponsored by:
Sponsored by: CARiD
deterred by ignorance
Old Jun 19, 2013 | 05:06 AM
Koromose's Avatar
I bought a used 2008 GSR a few weeks ago and with it being my first turbo car, I didn't know everything I was looking at. Now I can see the previous owner welded a HKS bov to the upper intercooler pipe (which I can only assume is aftermarket). I intend to do full bolt ons as if it were stock, but I'm left with an issue of not knowing where the factory wastegate was originally.
Also, should I go aftermarket when replacing the bov or get the oem wastegate? I'm sick of the venting to atmosphere, draws unwanted attention when shifting.
Old Jun 19, 2013 | 05:31 AM
Kendogg's Avatar
I've read the OEM BOV is pretty stout. I'm going to be adding on bolt on's myself. I plan on keeping the OEM BOV. My tuner recommends keeping it as well
Old Jun 19, 2013 | 06:49 AM
Iowa999's Avatar
I don't know if you're a sloppy writer or slightly clueless, but a "bov" (which really should be called a "diverter valve" or "compressor bypass valve") is a completely different part with a completely different function from a wastegate. The wastegate (on our cars) is part of the turbocharger, itself.
You should definitely get a recirculating (non-venting) compressor bypass valve. Not only because the noise is silly, annoying, and attention-attracting, but because it is bad for the engine (unless you are running pure speed-density or have a blow-through MAF post-valve).
Old Jun 20, 2013 | 05:27 AM
Koromose's Avatar
Slightly clueless, maybe a bit more than slightly.
Where is this valve supposed to be? Pretty sure not on an intercooler pipe
Old Jun 20, 2013 | 05:48 AM
donzilla2004's Avatar
Let's see some pictures?
Old Jun 20, 2013 | 05:57 AM
gsx1992's Avatar
Normally it's on the intercooler pipe and vents into the intake pipe pre-turbo.
Old Jun 20, 2013 | 09:25 AM
Iowa999's Avatar
Not just normally; that's how it has to be. The only thing that varies is whether the "in" to the valve is pre- or post-intercooler. On Mitsus, it's post-intercooler.
Old Jun 20, 2013 | 07:52 PM
FIST 13F's Avatar
It probably is recirculating. The HKS was on my car when I bought it and if you have aftermarket piping it will be LOUD. I could have sworn it was vented when I first test drove it, because I know for a fact my 8 was nowhere near as loud.
bosco121
17
Nov 8, 2014 02:03 PM
FstAsVR4
Jun 8, 2014 10:18 PM
Teamlacalle
Oct 31, 2013 11:05 PM
junkboxEvo
Feb 6, 2013 11:03 AM
