Sponsored by:
Sponsored by: CARiD
A "general" afr question
Old Jul 16, 2013 | 02:13 PM
Blue_05EVO's Avatar
Car runs and drives fine. But when I come to a stop te idle afr sticks at 12.8 -13.3 and if I just barely tap te gas it will jump around and land back up around 14.5-15.2.
My WOT afr are 11.7 tapering down to 11.34
And my cruise afr is 14.5-15.5 (this are the extremes if you watch it for a few min).
So it doesn't sound like I have a boost leak per say since the afr corrects itself after I tap the gas and doesn't mess up every time. But I would say a good 7/10 it does it.
Any thoughts on idle afr?
Old Jul 16, 2013 | 02:47 PM
ChipperEvo's Avatar
so you give it more gas at idle and the AFR goes higher? huh...
Old Jul 16, 2013 | 04:52 PM
Blue_05EVO's Avatar
I just tap the throttle and it jumps around then settles where should be. But if I am driving and come to a stop the afr sticks low. Then after tapping gas, afr jumps, ten settle where it should be.
Old Jul 16, 2013 | 07:09 PM
Blue_05EVO's Avatar
Bump for IA this weekend
Old Jul 16, 2013 | 10:35 PM
TravisF's Avatar
I'm pretty sure this is normal and no one has come up with a good explanation. Come up to a stop and idle afr sometimes goes to around 12.5 for a few seconds before going to normal 14.7
Old Jul 16, 2013 | 11:22 PM
Blue_05EVO's Avatar
I have searched and searched and seems only other problem I've found is afr that stay low.
It's almost like its fighting to say in closed loop or I guess fighting to get back in. But it does it from every stop/ slow down , not just from a all out wot even from highway to on ramp stop.
Plugs shall be replaced tomorrow an we will see!
But I'm worried something wrong in my tune.
Old Jul 17, 2013 | 03:20 AM
Blue_05EVO's Avatar
Is anyone coming to import alliance that would bring a 2.0 cable just so I can copy my rpm to computer sink can send it to get e-tune or if a tuner or sponsor will be there I could et a tune!!!
Just did all maint and fluids!!! Woo goo $$$
Old Jul 17, 2013 | 08:09 AM
nerdbotSKRA's Avatar
Are you downshifting when you're coming to a stop at a red light, or coasting in neutral when braking for a red light?
Old Jul 17, 2013 | 08:50 AM
Iowa999's Avatar
The god of English teachers just killed a kitten.
Old Jul 17, 2013 | 12:44 PM
Blue_05EVO's Avatar
Either way I've tried both.
Old Jul 17, 2013 | 12:46 PM
Blue_05EVO's Avatar
Not sure I get the joke lol.
I read it again and I didn't see anything wrong in my post ??
Old Jul 17, 2013 | 12:58 PM
adog's Avatar
Lol
Old Jul 17, 2013 | 01:48 PM
Iowa999's Avatar
The god of English teachers just killed a puppy (and wonders if you're going to go for the hat-trick).
Old Jul 17, 2013 | 02:56 PM
Well my theory of a richer AFR being present in your exhaust depending on how you're coming to a stop just got shot to hell.
Old Jul 17, 2013 | 04:16 PM
Iowa999's Avatar
I wouldn't give up on your theory (assuming that I understand it). Coasting fuel-cut can cause grief when the volume of the exhaust is large. The O2 sensor continues to see pure air for a moment after the ECU decides to start injecting fuel again. A simple blip of the throttle moves the pure air past the sensor and the ECU starts getting an accurate reading again.
