Sponsored by:
Sponsored by: CARiD
Exhaust leak question
Old Aug 18, 2013 | 11:38 PM
A Furr's Avatar
Hey guys I just installed the ultimate racing dual catback on to my X. That's the only thing I have on my car right now other than an hks drop in. I have a leak that I can't figure out between my stock cat the and the Midpipe. Will that cause me to run rich or anything? Is it a problem I should be worried about or am I just worrying for no reason?
Old Aug 19, 2013 | 07:44 AM
r34p3rex's Avatar
If it's post cat (and therefore after your O2 sensors), it won't cause you to run rich/lean. Only time you will have a problem is if you're leaking prior to the O2 sensors. In that case, the mixture reaching the O2 sensor will be leaner than it really is and therefore, your ECU will richen up the mixture to compensate
Old Aug 19, 2013 | 07:45 AM
r34p3rex's Avatar
Did you reuse the stock gaskets? It's good practice to use new gaskets (make sure you get 3 inch gasket) everytime you change your exhaust. Could also use a gasket filler material
ImsoevoX
Evo X How Tos / Installations
37
Apr 26, 2013 12:28 PM
Kraise
12
Apr 14, 2013 11:53 AM
Throttle
20
Jan 21, 2012 07:41 AM
evo4life400
Aug 13, 2009 04:52 PM
MitsuJDM
11
Jan 6, 2009 10:19 PM
