Hi everyone
. So I've had my 2011 evo x for a while now, and it's time to start adding some power. I want to make around 650HP-800HP. Also I'm going to be driving it daily... at low boost of course. and also want reliability. Plan on having it for a while too. This is the current build I'm interested in.
ERL Sleeved Block 2.0L
ETS T4 PT6466 Twin Scroll Turbo
Exedy Twin Disk Clutch
Jacks Transmission
I want to hear your opinions on this build, and a guess of how much hp it will make with high boost, cheers!
. So I've had my 2011 evo x for a while now, and it's time to start adding some power. I want to make around 650HP-800HP. Also I'm going to be driving it daily... at low boost of course. and also want reliability. Plan on having it for a while too. This is the current build I'm interested in.ERL Sleeved Block 2.0L
Jacks Transmission
My 2 cents:
It's gonna be a fun car no doubt, probably right at 600WHP, maybe a little higher if you go E85. The 2.0 with a T4 is going to spell lag; I'd go with a 2.2-2.4 and help spool a bit since you're having a whole new block put in anyway. The twin disk clutch will be OK for DDing, but there's almost no way it will hold up to launches with that kind of power, if you're going to launch you may want a triple, which in turn may suck for daily driving.
