Sponsored by:
Sponsored by: CARiD
ACD Pump disconnect for winter
Old Sep 23, 2013 | 08:02 PM
ddawg1130's Avatar
Went through 3 winters in chicago, car has been through 5 winters total now. I had mudflaps. Vehicle is at 50k miles and still running strong. I drove it all the time in chicago winters.
I believe the mudflaps did help some. The covers seem like good solutions, but you don't want to block cooling to the pump too much either. So it's a crap-shoot. But I think mudflaps make a good compromise and I think they look cool.
Old Oct 2, 2013 | 02:45 PM
RaX's Avatar
RaX
Originally Posted by DaEvoPusha
Edit: this is one of the options out there: http://www.dsgperformance.com/Carbin...rd-Evolution-X
That guard will NOT work on North American Evo Xs. It only works on RS models without AYC, and thus less hard lines coming to and from the pump.
Old Oct 9, 2013 | 04:13 AM
kijima's Avatar
I've done an AYC to RS rear conversion, the only difference would be the left and right channel lines. You could easily make the RS cover fit with not much additional work to it, but yes it's not a direct bolt on solution.
Old Oct 10, 2013 | 09:15 AM
Kartyman550's Avatar
how did you bleed the lines? take it to the dealer?
Old Oct 13, 2013 | 12:59 AM
kijima's Avatar
No, never done at the dealer as we have our own MUT3 to perform things like air bleeding.
Old Oct 13, 2013 | 03:40 PM
Cavdiddy's Avatar
Two MN winters here. Winter tires/ mud flaps = tank
Old Oct 13, 2013 | 09:42 PM
EvoXman23's Avatar
To OP, another preventive measure would be to put silicone were the pump pieces sandwich together as this is how the moisture gets inside. I don't know why Mitsubishi didn't put some kind of rubber gaskets between the pieces that sandwich together, this is like putting a head on a block without a head gasket. Also if you ever need to do a rebuild on the pump, checkout ACD-tuning.com they offer a rebuild kit. This is how I found out about the silicone idea.
Old Oct 14, 2013 | 09:59 AM
Iowa999's Avatar
There's no rubber between the parts because there's a plate inside that must be hard against the body of the pump or it won't hold pressure. They could have used better O-ring seals, but they can't use rubber between the parts.
Silicone with a layer of heavy grease on top, as Kiki has told us several times.
Old Oct 14, 2013 | 10:22 AM
EvoXman23's Avatar
Good info, I never thought about that. Any specific grease to use?
Old Oct 14, 2013 | 01:00 PM
Iowa999's Avatar
Thick and waterproof, e.g., http://www.lucasoil.com/products/dis...id=14&loc=show
kyoo
Apr 15, 2015 02:20 PM
FilthyEvo
Nov 2, 2012 04:10 PM
51
Nov 17, 2010 05:44 AM
Bosshog
18
Jun 19, 2007 10:58 PM
Gumpy
Jan 24, 2006 04:41 PM
