Sponsored by:
Sponsored by: CARiD
380 whp possible with these upgrades?
Old Nov 12, 2013 | 02:03 PM
turbodreamz21's Avatar
So plan on doing these mods on stock turbo with 93 pump on a 2012 evo x gsr
Turbo manifold ,
Map 02 delete DP
TEST pipe
Single exhaust 3"
Intake
Fmic
Uicp
Licp
Cams
Fuel pump
Injectors
What could possibly be some number I might look to expect? Would like to see 400whp but I have read that won't happen without E85 and I don't have that locally to run it.
Old Nov 12, 2013 | 02:48 PM
wangboy925's Avatar
There's people with those mods listed, minus the cams, running those numbers. Yes its possible but it all depends on how good the tuner is.
Old Nov 12, 2013 | 03:33 PM
Kendogg's Avatar
Seems possible. I have the mods listed in my signature and I was tuned at 337 on 93. I think it was a conservative tune and it was really hot outside.
Old Nov 12, 2013 | 04:24 PM
Igaly1021's Avatar
its all in the tuner man, but i dont see why not since evo x already bring a decent turbo size
Old Nov 13, 2013 | 01:03 PM
sleeper01's Avatar
why not buy a turbo also? you have all the supporting mods, you can hit 400 without the cams.
Old Nov 13, 2013 | 01:05 PM
Kracka's Avatar
Agreed, skip the cams and get a turbo. Better gains with better drivability
Not even counting labor, cams +springs cost about the same as sending your turbo in to MAP for an upgrade.
http://turbos.maperformance.com/evox-turbos.html
(see left side of page for upgrade information)
With stock cams and 93-octane, I've made 400whp with the EF2 and 425whp with the EF2.5 on a Mustang dyno.
Old Nov 13, 2013 | 01:07 PM
Mistaken's Avatar
^ This!
Old Nov 13, 2013 | 01:09 PM
InoNothingMR's Avatar
My mod list got me to 365/350 to to wheels if that helps for reference. So personally I would say you will fall short, but some cars make more power than others so who knows!
Also going to hop on the "buy a turbo" bandwaggon.
Old Nov 13, 2013 | 01:16 PM
Kracka's Avatar
For reference, my stock turbo maxed out around 352whp (stock cams & 93-octane) on the same dyno I mentioned above.
Old Nov 18, 2013 | 08:05 AM
tellme718's Avatar
No. Minimun need a turbo upgrade and/or e85.
Old Nov 18, 2013 | 08:11 AM
Sharkbite2000's Avatar
Look's like 330 - 340 awhp with those mods on pump gas of course
Old Nov 18, 2013 | 08:42 AM
shekaar's Avatar
Nobody wants to point out that he could make 400whp on one dyno with the mods, and 340 on a more conservative dyno with the same mods and tune?
I do agree, lose the cams and do a turbo.
However, don't put too much stock in the numbers...they can vary greatly between dynos and tuners.
Old Nov 18, 2013 | 10:19 AM
thenewcraze's Avatar
Appears possible.
Hollywood tuned me right at 365/350 w/ TBE, FMIC, U/LICP, 3-port, intake on 93 (in Texas).
Old Nov 18, 2013 | 10:34 AM
novaspyder87's Avatar
400 whp is VERY possible with cams on a stock turbo...and a manifold...if you want to make so to get those 400whp....port that stock turbo and buy a WGA so you wont tapper that much up top!!!
the key to getting power is THE TUNER!!!! .....and the dyno LOLLLL
Old Nov 18, 2013 | 01:20 PM
tellme718's Avatar
I have yet to see someone post 400whp from a stock turbo w/o E85 with any other mod. Cams, IC, Manifolds etc...listen to kracka. He clearly stated what his stock turbo maxed out at. And kracka ain't no sucka.
