Sponsored by:
Sponsored by: CARiD
EVO X MR MODS/WHP/TQ and how is your SST doing?
Old Nov 16, 2013 | 09:19 AM
Storm Shadow's Avatar
Originally Posted by Grape Juice
Careful with your torque levels. If you're not already aware, I keep reading that the SST gets weak past 350TQ. #IJS
When I read your post I thought about this commercial. I've read the same stuff but you have to think different tuners different results.
Old Nov 16, 2013 | 09:44 AM
Jake.barratt's Avatar
Interesting.
Old Nov 16, 2013 | 10:14 AM
thegoodservant's Avatar
08 mr
40k ETS intake, upper pipe and test pipe. 315 whp and 300 wtq no issues. Just changed the SST fluid recently, noticeable difference after the change in the shifting.
Itching for more power! Down pipe and exhaust coming soon.
Old Nov 16, 2013 | 11:10 AM
Grape Juice's Avatar
http://www.youtube.com/watch?v=bufTna0WArc
Haha word!
Old Nov 17, 2013 | 06:00 PM
Risky Guy's Avatar
I'm at 347awhp/300awtq @26psi.
Mods are
Ets intake, ets uicp
GS 3 port boost control
Turbo xs turbo back with HFC
With a professional tune
Old Nov 17, 2013 | 09:24 PM
IRISHEVOX's Avatar
i see everyone is aroud a similar level.... seems like i have a ton of mods and not making as much power as i should
Old Nov 18, 2013 | 06:26 AM
tellme718's Avatar
Originally Posted by Masheen
SST is slipping trying to get into 1st from a complete stop. Lightly gassing increases RPM then sounds like car is about to stall then clutch engages. Doesn't happen a lot, but it happens. Wished more tuners would tune SST along with engine.
Sorry to say but your whp is pretty low with those parts. Also considering it was tuned on Iveys dynojet. Ive heard from many people hes not as good as he used to be. Unless your spending tons of money on a tune with him, he doesnt give it his all. I would contact one of the many etuners on here that would fix your tranny problem AND get you more horsepower for less money. Ivey is a ripoff I hear.
Old Nov 18, 2013 | 10:53 AM
Masheen's Avatar
So it seems that way. Although he did take over 2 hours and pulled my car 20 times on his dyno, the end result was a super conservative stage 1 tune on a stage 2 car with no compensation for the SST transmission. I'm looking into other options now. I am strongly considering an E-Tune from Hollywood.
Old Nov 18, 2013 | 11:29 AM
datten's Avatar
I'm currently running Cobb AP V3 Stage 1 ACN LWG 91 map, Cobb SS Oval Exhaust, and Cobb SF Intake. Granted not that many mods by any means, but the difference between then and now, is shifts seems to be a little harder and felt in the cabin. Other than that, no slipping.
Old Nov 19, 2013 | 04:56 AM
tellme718's Avatar
Question
Aren't you from EE? I thought ya worked with chet?
Old Dec 2, 2013 | 02:28 PM
odin's Avatar
Lightbulb
Wow, that's what Exactly happen to mine too. I was told the car makes about 340whp and tq. It happened.on my track days =( Later on, tuner adjusted my sst tabke and increased clutch engage force. But no track event yet since then, only time will tell lol. Daily drive is just fine
Old Dec 3, 2013 | 05:02 AM
Zombie Killer's Avatar
Stock so far, no issues. Just shy of 19k on a '10 SE. Doing a build in the spring FMIC/CAI/DP/TP/CBE/Cams/Tune.
Old Dec 4, 2013 | 01:16 PM
EvoSmile's Avatar
2011 MR with the following mods on 91 pump gas:
- ETS 3.5" FMIC, UICP, LICP
- AMS HFC
- Greddy SE CBE
- Cosworth drop-in intake filter (stock box)
- RRE boost pill
Going to get it tuned at RRE in couple weeks. What #s should I expect?
Old Dec 4, 2013 | 01:35 PM
shekaar's Avatar
Depends on the dyno. My tuner has seen stock MRs make less than 200whp w/ 93 oct on his dyno. Other people on here say that 350whp is "50whp more than stock." That, generally, would be false. That could be upwards of 130-150whp over stock.
Don't have expectations going in, don't put too much stock in the numbers, and just judge the worth by how it feels
Old Dec 4, 2013 | 04:16 PM
Masheen's Avatar
It has to be the SST tables because sometimes when I shift out of reverse into 1st I feel like I'm about to stall. Meh... I notice also that when doing a WOT pull with redline shifts, shifting from 3rd to 4th gear puts me at 5k rpm and I feel as if I lose acceleration because I have to shift into 5th so quickly. It should put me at 3.5k-4k so that I feel that I have enough torque to accelerate. I dunno, it just doesn't seem smooth. Something is up.
