Sponsored by:
Sponsored by: CARiD
Product that can display,rpm boost afm ect on double din
Old Dec 10, 2013 | 11:53 AM
braedenb2's Avatar
Hey I'm looking to see if anyone knows of any product or apps that allow you to view, boost , rpm, afm, ect. On iphone or double din display???!I know I have see on other forums about a Bluetooth device witch was very inaccurate. Let me know what you go !?!
Old Dec 10, 2013 | 12:10 PM
ikt's Avatar
ikt
Torque pro is the android app and the bluetooth adapter is about 20 bucks
Old Dec 10, 2013 | 12:20 PM
braedenb2's Avatar
Is it any good tho?
Old Dec 10, 2013 | 12:21 PM
ikt's Avatar
ikt
Originally Posted by braedenb2
Is it any good tho?
it's outstanding.
it does not read AFR though, no OBD2 based reader will. For that, you need some sort of interface like the Innovate LC-1. I personally have an innovate wideband controller that reads to my Greddy Informeter touch. That is the easiest method to do it.
Old Dec 10, 2013 | 03:53 PM
fd2ap2e92's Avatar
x2
Old Dec 10, 2013 | 04:30 PM
TrogdorWBL's Avatar
Torque isn't as good as people think it is. I have it. Its connects to the ECU. The ECU in our car, fortunately, doesn't read a lot of things that you would want it to.
It doesn't read boost real well. On the dyno my car is running at 30 PSI. Toque doesn't show it past 24 even if you increase it's max display. It has options to show fuel pressure, and oil pressure. But our ECU doesn't take constant readings. It just monitors whether or not it surpasses a certain critical point (for both). It can measure AFR, but that's just using your standard O2 sensor. It doesn't read it if you're using a wideband.
It's cool to play around with, but if you want to to measure vital signs of your car, it just don't work that well with our ECU.
Old Dec 10, 2013 | 04:36 PM
ak47po's Avatar
http://www.plxdevices.com/product_info.php?id=MULTDM6
Or this...http://www.plxdevices.com/product_in...MULTDM100TOUCH
Old Dec 12, 2013 | 11:38 AM
Veronica's Avatar
Pioneer AppRadio2 (or 3) with DashCommand (custom skins for the display) and a ECU wireless reader.
DashCommand will accept a wideband
Old Dec 13, 2013 | 02:46 AM
MDH-005's Avatar
I couldn't find anything that was worth having, so I had this made and got some quality STACK gauges.
Old Dec 13, 2013 | 02:47 AM
MDH-005's Avatar
Old Dec 13, 2013 | 03:29 AM
rick1024's Avatar
http://www.plxdevices.com/product_in...MULTDM200OBDII
genesisevo
Feb 11, 2016 04:44 PM
BadassEvo8
Apr 12, 2015 01:58 PM
genesisevo
Mar 28, 2014 05:52 PM
EvoIXPilot
Nov 30, 2012 06:46 PM
mr soul
Apr 30, 2012 06:31 PM
