RPM Bounce/Jump Idle
Nobody likes to look in the tuning section so I'll post here.
Very rarely my RPM's bounce from 800-1K (?). It's happened 3 or 4 times since my tune in December. Mods are full bolt ons minus FMIC and LICP on 91. It's def not the AC and the heatshield issue. Any ideas? Other than that the car runs and pulls great.
SEAFOAM! I had an idle issue it would drop to around 600 or jump up to like 1.5k. Ran some SeaFoam in the Gas tank, Oil , and also sucked in the vaccum lines. after that havnt noticed an idle issues.
This is just my experience though.......
No it doesn't die. It never hesitates. The RPM just bounces and stops. Lasts maybe 5-10 seconds? I've never really let it sit there and do its thing, I rev it and it goes away.
FWIW, I did get tuned in pretty cold weather. 55-65 if I had to guess.
Is it significantly warmer now than it was? Evo 10's calculate both MAF and MAP for idle and fuel, so if one of those is off as a result of temp, it can do weird things. Looks like RRE was your tuner tho right? Have you talked to them? They're great people.
No, I haven't called RRE yet. That's my next step. It's a bit warmer during the day, but at night it's about the same as December mid day.
Stock evos have the problem too. May be or may not be your problem.. http://www.evoxforums.com/forums/showthread.php?t=56314
I havent been able to figure out the cause to my issue(s). I think I may get a different tune from a different tuner to see if it is caused from the tune. I have had tuners offer to look at my tune for me, but since my tuner decided to lock my tune for some odd reason, I can't get a second opinion without getting the thing retuned. I'll let you know if this fixes my issues. Let me know if you figure out yours.
