Sponsored by:
Sponsored by: CARiD
Will these wheels fit?
Old Mar 11, 2014 | 12:56 PM
mmack104's Avatar
I'm buying a set of Volk TE37s 18x8.5 +30. I am just making sure these will fit with no adjustments.
Old Mar 11, 2014 | 01:21 PM
ogrenator's Avatar
for some reason I'm second guessing myself but they should fit just fine
Old Mar 11, 2014 | 01:28 PM
f-dub's Avatar
They will fit no problem. Stock is 18x8.5 +38 so these rims are the exact same width, just pushed out 8mm further.
Old Mar 11, 2014 | 02:45 PM
ikt's Avatar
ikt
you might need spacers
Old Mar 11, 2014 | 03:36 PM
wwEVOsss's Avatar
^ Agreed. chance you'll need spacers. You should buy some anyway to make them fit better. +30 is too high IMO. Are you getting a deal on these? If not you should buy a better size and offset
Old Mar 11, 2014 | 07:11 PM
Iowa999's Avatar
Just to be clear as to what the posts after the above quote are saying: the offset is fine, at least in terms of keeping the wheels and tires off the suspension and away from the fenders, but high-offset Volks can have very straight spoke, so the question is whether the wheels will clear the front brakes. I agree with the last few folks that there's a good chance that spacers will be needed to keep the spokes off the calipers, but have no direct experience either way.
More generally, folks (including the author of the above quote) need to be careful about thinking only in terms of offset. We have fixed calipers. These stick out a lot more that floating/sliding calipers. You need to think about the spokes clearing the calipers, rather than just what the offset will do to the tire's location.
Old Mar 12, 2014 | 08:00 AM
f-dub's Avatar
Agreed, I didn't immediately think of that and should have included that warning in my post above. Unfortunately I don't really see there as being any way of knowing without fitting the wheel in most cases. I do know that most of the TE37 knock offs (all I can afford) barely clear the calipers with a +22 offset so if that is any indication the TE37's he is looking at might not fit without a spacer.
Old Mar 12, 2014 | 10:10 AM
Iowa999's Avatar
Most of the sponsoring vendors that sell wheels will be happy to find out if a given wheel will clear our brakes. That's what they do. Send one (or more) a PM.
Old Mar 12, 2014 | 12:34 PM
Ramthug's Avatar
most run +12 to +20 in that range, +30 is sunk
amsevokid
Mar 3, 2014 08:30 PM
PaulyX
Dec 28, 2013 06:51 AM
R3BB
Oct 3, 2013 06:11 PM
youngcow
Jan 29, 2013 08:12 AM
extremier
Mar 24, 2008 06:16 PM
