Sponsored by:
Sponsored by: CARiD
3 Port Intake Port?
Old Mar 26, 2014 | 10:27 AM
jmichetti's Avatar
3 Port Intake Port?
Went to my tuner yesterday. Had them install the grimmspeed 3 port. Port 1 the intake port the left open and venting and capped off the cobb intake its self. Is this normal? Any advantage / Disadvantage ?? Made 360 corrected on a dyno jet btw
Old Mar 26, 2014 | 10:51 AM
chundizzy's Avatar
I believe the 3rd port is used for an external waste gate. SOmeone else correct me if im wrong.
Old Mar 26, 2014 | 11:00 AM
powerdriver's Avatar
1 - compressor side of turbo
2 - wastegate
3 - intake
That's how I have mine setup. Not in that order since the ports are named 1-2-3
Old Mar 26, 2014 | 11:13 AM
stvn87903's Avatar
The one that goes to the intake is just a vent. No reason to connect a line or do anything with it, it just needs to be open so it can bleed off your excess boost pressure.
Old Mar 26, 2014 | 11:19 AM
alsong2002's Avatar
no need to connect the intake side.
Old Mar 26, 2014 | 11:48 AM
jeffbeagley's Avatar
While this diagram is made for a slightly different setup, it should answer your question!
Old Mar 26, 2014 | 02:28 PM
jmorris1027's Avatar
http://www.grimmspeed.com/content/in...ne_version.pdf
4. Hook up vacuum lines to the GrimmSpeed BCS. You will be removing the 2 factory vacuum
tees. See Figure 2. Port 3 connects to a high pressure boost source (there is a vacuum nipple
on the turbo compressor outlet). Port 2 connects to the internal wastegate actuator vacuum
nipple and Port 1 should be routed back to the intake (where the factory BCS mounts). It is
recommended that a plastic zip tie is used to secure vacuum lines. The electrical is plug and
play with the supplied connector. Tuning: WGDC controls the actuator / turbo. Tuning to the
WGDC is required (approx 30% reduction in WGDC)
evotreb13
Sep 13, 2015 10:27 PM
rz
Sep 2, 2015 02:03 AM
MivecAddict
Aug 24, 2012 07:21 PM
nj1266
Jun 27, 2009 03:08 AM
Evo3GEclipse
21
Jun 14, 2007 07:36 PM
