Sponsored by:
Sponsored by: CARiD
which catback would be best?
Old Mar 31, 2014 | 08:28 PM
ivandelgado's Avatar
I decided to go for a catback next but having a hard time figuring out which one to get, if you guys have experienced this exhaust please let me know what you think about them?
http://rawevo.com/store/shop/exhaust...xhaust-system/
Old Mar 31, 2014 | 08:31 PM
or would a Downpipe be better to install first? am seeking power on the car so I want to get some basic bolt ons before I go looking for a tunner.
Old Mar 31, 2014 | 09:56 PM
Raw Evo's Avatar
It all depends on how how much sound you want.. You def do not need a downpipe right now.
The first link you posted is quite loud. I find a lot of people sell their ETS regular exhausts and end up going for the V2 Quiet exhaust as it doesn't drone on highway rides and sounds awesome on wide open throttle.
Old Mar 31, 2014 | 10:17 PM
TrogdorWBL's Avatar
Neither.
Cat back will only help a little bit, other than change the sound of your exhaust. It's by no means the best bang for your buck if you want power.
And the car was designed well for it's stock turbo. Meaning the intercooler and down pipe to a very good job of handling the amount of air flow intended for the stock turbo. There's not much reason to change either until you change turbos.
Best bang for your buck is to delete the cat (test pipe if allowed where you live), boost controller, and e85 if you have it where you live. Dollars to HP you won't getting more power for cheaper than with e85.
Old Mar 31, 2014 | 11:49 PM
ok thank you guys and yeahh your right ill just do test pipe now, just bought it from RAW EVO. what would be good to change next?
Old Apr 1, 2014 | 07:20 AM
f-dub's Avatar
Install the test pipe then get a tune. Ask your tuner what to do next. IMO the next thing to do is upgrade the turbo to a larger stock frame turbo (FP green, BBX, MHI, etc.). If you just want more noise from the car then get an intake.
Old Apr 1, 2014 | 09:29 AM
great ill do thaat then and yeah I have a ets intake all ready
Old Apr 1, 2014 | 10:26 AM
ETS Michael's Avatar
The intercooler is worth around 15whp in 3.5" form on the stock turbo and the 4.0" around 22whp. The factory intercooler is undersized for the stock turbocharger. Also with the increase in boost pressure and moving the turbocharger out of it's efficiency range the intake temps are much higher and the bar and plate intercooler does a much better job at keeping the intake temps lower. The recover rate between pulls is also much faster with our intercooler compared to the factory intercooler.
The best bang for the buck mods on the Evo X is the intake/boost controller, upper pipe, test pipe and intercooler in my experience. Of course a tune as well
If you need any help let me know.
We have full bolt on packages you can get from us or our vendors.
http://www.extremeturbosystems.com/E...Package-1.html
and
http://www.extremeturbosystems.com/E...Package-2.html
After both packages are installed... All you need is a tune and your own your way to 360+ whp.
Michael
Old Apr 1, 2014 | 12:50 PM
Robevo RS's Avatar
Most power for a same price or even cheaper as a quality cat back would be : get rid of the stock cat
and get a new panel filter + appropriate tune.
Old Apr 1, 2014 | 01:47 PM
evostanman's Avatar
Or... try Top Speed Pro 1
Great bang for your buck when it come for TBE.
Old Apr 1, 2014 | 05:17 PM
Jdjones24's Avatar
I went with the ETS Quiet Catback, High Flow Cats and Cold Air Intake. I also have a 4" inch intercooler with hard pipes. To me, that's all I need in terms of power because the car is my daily driver. I'm not about to waste 5 figures on aftermarket parts because the car would be pointless to drive afterwards. You can't go wrong with ETS or AMS. Make sure you get a tune regardless of your mods. Tunes are the best investments.
Old Apr 1, 2014 | 08:13 PM
thank you guys this was that help I was seeking now I know whats my next steps,,,, also thank you Michael from ETS for replaying to my posts and giving me real info about your products, and of course RawEvo for having awesome prices!
Old Apr 1, 2014 | 08:17 PM
also one more question Michael, if I get the 4.0'' intercooler would it fit too tight or would it fit just fine?
Old Apr 1, 2014 | 08:37 PM
doom26464's Avatar
and
Michael
michael can you run your intercooler without a tune? or does it effect the tune too much that your car should be re-tuned when one of your intercooler is installed?
Old Apr 1, 2014 | 09:13 PM
just purchased my Upper pipe, cant wait to install....
so far I will be having,
-ETS intake
-ETS Test Pipe
-ETS upper pipe
-Turbo Smart BOV
-and ETS Intercooler soon ..... do you think I need the boost controller?
