Sponsored by:
Sponsored by: CARiD
right bolts for turbo?
Old Apr 9, 2014 | 06:10 PM
newevoxguy's Avatar
Can I use bolts from the hardware store for turbo to down pipe and also exhaust mani?
Old Apr 9, 2014 | 07:36 PM
newevoxguy's Avatar
Did my post just get spammed
Old Apr 9, 2014 | 08:38 PM
Thomar's Avatar
lmao.
Old Apr 9, 2014 | 09:28 PM
Gqracer's Avatar
U r better off getting mm bolts at ur local auto parts store. I had to buy new bolts for my o2 down pipe at Auto zone. They come in little package of 4-6 bolts in 10, 12, 14,17 etc mm size. Nuts are sold separately.
Old Apr 10, 2014 | 03:27 AM
Johnr352's Avatar
You want automotive bolts that are strong. They have these at your hardware store, and will at your automotive store. I don't know too much about bolt grades but look for those with a 10.9 stamped on the head, not 8.8.
Old Apr 10, 2014 | 03:50 AM
AWDTerror's Avatar
Buy the bolts from Mitsu, the contain some sort of witchcraft that allows them to expand more than bolts you can get at the hardware store which keeps them from backing out. If you get bolts from the hardware store you will have to go back and retighten them every oil change.
Old Apr 10, 2014 | 11:23 PM
newevoxguy's Avatar
Ok thanks guys
Old Apr 12, 2014 | 07:32 AM
IRPerformance's Avatar
I use these http://www.clipsandfasteners.com/M10..._p/pm33630.htm
Old Apr 19, 2014 | 11:01 AM
supwiddiss's Avatar
Bolt grade markings. You want hard bolts for the turbo. If you have access to a small acetylene torch you can heat the casting (carefully...just "tip it") and bolts come out w/o snapping. I choose dealer bolts always.
Old Jan 23, 2015 | 03:02 AM
basher519's Avatar
^ what they said, oem. I tried the longest time to find decent ones, arp makes replacements that are probably fine (haven't tried em) but I just went oem since I wanted them faster and I've never had problems with oem backing out.
And make sure to use the double washers for the mani/turbo bolts and studs. They are installed with the dots facing away from each other.
Old Jan 23, 2015 | 04:10 PM
newevoxguy's Avatar
I went to mitsubishi and got all bolts and washers. Thanks guys
Benja258
Sep 22, 2016 05:21 AM
RedEvoxGSR
Feb 6, 2016 08:43 PM
rage mang
Dec 11, 2013 03:45 AM
Lukelis
Feb 15, 2013 05:15 PM
Matt_Jagg7
Sep 25, 2010 04:30 PM
