Sponsored by:
Sponsored by: CARiD
Intake install help!
Old Apr 16, 2014 | 11:05 AM
Evo82's Avatar
What arw those 2 holes for??? Thanks
Old Apr 16, 2014 | 11:09 AM
Evo82's Avatar
And that nipple is on my way..theres only one...thanks
Old Apr 16, 2014 | 11:20 AM
shekaar's Avatar
That's the intake cone? You use those holes to mount the filter to the intake piping I believe.
There's a really good install guide floating around here...
https://www.evolutionm.net/forums/ev...all-guide.html
Old Apr 16, 2014 | 11:46 AM
Evo82's Avatar
Yes it is...bit big..I figured ot..had ti cut that nipple off to make it fit...just need to figure out the lines adjust amd good to go
Old Apr 16, 2014 | 11:47 AM
Evo82's Avatar
Thats what I been using for the install. .just confirmed with the lines
Old Apr 16, 2014 | 12:02 PM
shekaar's Avatar
You shouldn't be cutting anything to install the ETS intake. The graphics don't show up on my work PC or I would look closer, but I'm fairly certain you shouldn't be cutting things off of the intake..
Old Apr 16, 2014 | 12:23 PM
Evo82's Avatar
Not the intake. .there was a plastic nipple on maf adapter where the gaskets goes...only on one side..I filed down just a bit and its a perfect fit...this is more time consuming then I thought
Old Apr 16, 2014 | 12:27 PM
TravisF's Avatar
There should be a threaded stud that goes into that hole to hold the MAF housing to the intake. When you take the MAF adapter off the stock intake the bolts usually strip out of the plastic and so you need a new way to attach the maf housing to the new intake. This picture might help:
Old Apr 16, 2014 | 02:25 PM
Evo82's Avatar
Attachment 222331
Click image for larger version
Please help again...I cant figure where they go..I have a trial q bov.i aslo have a line that came with the intake and goes from yje bov to somwhere..thanks guys
Old Apr 16, 2014 | 02:33 PM
Evo82's Avatar
Think I got it
Old Apr 16, 2014 | 04:40 PM
Evo82's Avatar
So I got it all in car runs...but my rpm is at 2k..not always..juamps up and down...will this be an esue? Its a ets..sorry
Old Apr 17, 2014 | 09:49 AM
ikt's Avatar
ikt
sounds like a vacuum leak
jfeo
10
Jun 30, 2015 12:11 PM
jcroswell
Oct 13, 2014 12:31 PM
timmycat
Jun 12, 2014 05:20 PM
David Fogleman
May 18, 2014 06:08 PM
mjp10mlrsb
09+ Ralliart Show and Shine
Jan 10, 2014 11:47 AM
