Sponsored by:
Sponsored by: CARiD
Normal wear or suspension issue
Old Apr 22, 2014 | 02:23 PM
Risky Guy's Avatar
Own a 12 mr & have had no odd issues except one listed below.
Having very unusual tire wear in front & rear.
Have rotated tires every 5k& also had alignment done at 3k & again at 5k. Car was pulling to the left. I'm at 12k now & the wear has got me worried I may have a suspension problem. Even though it was checked by 3 different mitsubishi dealers, now I'm a little worried. I'll know tomorrow when tire distributor may cover the stock rubber, only
if alignment is dead on. The car has had no issue since 2nd alignment, it goes straight as an arrow. Was thinking is it possible I need a aftermarket camber kit.
Also,I'm 100% stock as far as suspension. Any opinions or ideas, please let me know, don't really want to rely on dealership since no one can seem to see any issues. Thanks again for the help.
Old Apr 22, 2014 | 08:20 PM
Thomar's Avatar
Post the print out u get of your alignment from the shop.
Old Apr 23, 2014 | 06:17 AM
Veronica's Avatar
Pix of the wear on the tires as well.
Old Apr 23, 2014 | 07:05 AM
Risky Guy's Avatar
Will do, tires are down to 4/32 so not much left. Right rear is slightly out, I'll post specs when I get home from work. Thanks for the input.
Old Apr 23, 2014 | 09:53 AM
ikt's Avatar
ikt
the stock tires are made of bubble gum but only last about 10k miles
Old Apr 23, 2014 | 02:23 PM
Risky Guy's Avatar
Ok I'm using my phone I can't attach the image.
Left front camber -0.8
Left front caster 3.8
Left front toe 0.08
Right front camber -1.1
Right front caster 3.9
Right front toe -0.04
Front total toe 0.04
Steer ahead 0.06
Left rear camber -1.2
Left rear toe 0.18
Right rear camber -1.0
Right rear toe 0.27
Rear total toe 0.44
Thrust angle -0.04
This alignment spec is a train wreck. No wonder my tires are destroyed..
Obviously, alignment is out of spec.
Old Apr 23, 2014 | 02:47 PM
meckert's Avatar
Toe is out---especially the rt rear with better then 1/4 toe. I would highly recommend you get to a shop that can set everything up correctly... I can see camber being out a little and not identical side to side but no reason toe is not the same at the very least side to side and that rr setting is a joke.. you dont need camber plates you need a good alignment from a reputable shop.. have them set toe to "0" up front and the absolute minimum in the rear--"0" if they will do it and your probs will go away.
Old Apr 23, 2014 | 03:17 PM
Risky Guy's Avatar
Thank you for that reply.
Can it be a aligned if tires aren't 100%?
Was planning on dumping the stock advans. I live in Staten Island ny, pothole Capitol of NYC.
TheHolyLancer
Aug 10, 2016 08:09 AM
David Buschur
225
Dec 12, 2014 09:31 AM
ElusiveTurtle
Dec 13, 2011 09:06 PM
bossssman38
10
Dec 12, 2011 07:03 PM
XK120
Sep 10, 2008 11:15 PM
