Sponsored by:
Sponsored by: CARiD
[AYC Pump] ...Solution yet??
Old May 22, 2014 | 01:08 PM
Phantom_x2's Avatar
Lightbulb [AYC Pump] ...Solution yet??
1. Installing custom box around pump.
2. Sealing it with anti-corrosion, silicone, etc.
3. Rebuild kit.
4. Pump relocation...
Has anyone found a solution that actually works?
From what I gather, it's the cold temps with moisture that causes corrosion on the outside of the pump and travels inward. This brings me to the conclusion that a relocation kit and box cover won't do much since it's still cold in the trunk during winter.
I've talked to some techs at various Mitsubishi dealerships and they had said that the rebuild kit from the US doesn't last long - if at all.
The Evo is a sweet car... but Mitsubishi doesn't seem to care much about this issue that's been around for quite some time already.
Has anyone tried these methods or anything that seems to work over time with good results?
Old May 23, 2014 | 05:57 AM
Veronica's Avatar
A trunk mount still protects from road salt & water and would be best.
The cold exacerbates corrosion - but does not cause it.
Old May 24, 2014 | 05:50 AM
Chafed Banana's Avatar
When my pump failed and I had to spend big bucks on a new pump. I decided putting it back in the same place would be insane. I wanted a permanent solution. So I relocated it to the trunk. It took finding a place that could make the line extensions with the fittings I needed (and that wasn't cheap either, about $600). That was the hardest part. The wiring harness has the necessary length, it just needs to pulled out of the bumper and run directly down from the top of the trunk where it comes from, down to the pump (no splicing or anything required). But other than that I am very glad it's in the trunk now (all the way to the right side), nice and dry and totally protected.
Old May 24, 2014 | 11:13 AM
Phantom_x2's Avatar
I see u have an 08' - how many km's so far on the pump relocation? Did u use a special kit to do that?
Old May 24, 2014 | 11:15 AM
Phantom_x2's Avatar
Good point - thanx!
Old May 24, 2014 | 12:36 PM
littlezrexer's Avatar
I believe some jdm or Russian companies make a box to protect it from corrosion.
Old May 26, 2014 | 10:45 AM
hispanicpanic's Avatar
I'm a little unfamiliar with this problem, can someone provide more information on how long the ayc pumps typically last? If i'm in Texas with no salt on the roads, am i relatively safe from this issue?
Old May 26, 2014 | 12:09 PM
ChUt26's Avatar
You're not as vulnerable, but you are not necessarily safe.
Old May 27, 2014 | 07:28 AM
mclaren's Avatar
High temps can also attribute to the ayc pump failing. I know first hand since mine is on it's way out. Seattle weather this year hasn't even been that hot yet.
Old May 27, 2014 | 09:02 PM
Evo_chick88's Avatar
I had to rebuild my ayc pump when I got the car and mine has been fine with the rebuild kit for over a year now.
Old May 28, 2014 | 07:02 AM
Sephiron's Avatar
There was a thread of someone who made or found some plates that shielded the pump. Kind of a splash guard of sorts. Not sure who made it but it would be worth looking into as I cant find it at the moment.
Old May 29, 2014 | 03:35 AM
DGS's Avatar
DGS
Anyone try just coating it with rhino liner or liquid latex?
Has Mitsu improved the newer ones?
Old May 31, 2014 | 11:27 AM
Phantom_x2's Avatar
Was thinking about that - but not sure if that would insulate the pump or not... I don't think more heat would be good on the pump motor. At the moment there is a dealer in Canada that's undercoating them supposedly.
And to my knowledge - Mitsubishi has not improved the newer ones since the 2014's are the same as the 13's.
Old May 31, 2014 | 11:29 AM
Phantom_x2's Avatar
Interesting.
Old May 31, 2014 | 11:30 AM
Phantom_x2's Avatar
Ditto.
Davedangerous
75
Aug 16, 2019 10:26 AM
Alchem1st
Oct 2, 2017 06:42 AM
mattusmc
For Sale - Cars For Sale
Apr 6, 2016 04:27 PM
mcm308
13
Jan 19, 2013 10:30 AM
fireroasted
Aug 24, 2012 10:58 PM
