Sponsored by:
Sponsored by: CARiD
Gas gauge problem?!?
Old Sep 19, 2014 | 04:30 AM
1ucky11's Avatar
Hey guys, this is the second time in a row this has happened. I went to the pump and filled up my tank. I set the pump and let it go till it automatically stops. Get in my car, and my gas gauge isn't all the way full. It shows up as 8/10 full. Has anyone had this problem? What is going on?
Old Sep 19, 2014 | 06:02 AM
kosteniuks17's Avatar
Damn that sucks man. Is this on flat ground, or are you on a hill. Did you try to put more gas in there after the automatic shutoff? Hey you have a 2014, so it might be a bad sensor, just take it to the stealership.
Old Sep 19, 2014 | 06:18 AM
nvmaddog's Avatar
That's not the gauge, it's the way you had the nossle on the pump inserted.
It automatically cut off because it was most likely at a funny angle in the tank when there was still more room for fuel.
Old Sep 19, 2014 | 07:47 AM
richdmz's Avatar
I have a 2014 as well and no issue, maybe try holding the nozzle rather then letting go on auto and fill till it stops and see if your results differ. If you still have the same issue check with the dealer.
Old Sep 19, 2014 | 09:33 AM
vitamin4b11t's Avatar
I've filled up before and have had the same issue with the gas nozzle stoping before full but i just repositioned it and worked, i guess try it again and if the same thing happens just take it to mist
Old Sep 19, 2014 | 10:49 AM
kiddsevo11's Avatar
How many Gallons are you being able to put into your car?
Old Sep 19, 2014 | 11:54 AM
.M.'s Avatar
.M.
I never use the "auto" anymore. It would always cut off early, way to early, or not work at all. I don't even try anymore.
Old Sep 19, 2014 | 12:02 PM
Ev0ikon's Avatar
That's too hard of a question. Easier to just go on here and post.
Old Sep 19, 2014 | 03:11 PM
1ucky11's Avatar
Umm i had a 1/4 tank. It took 8.233 when it shutoff.
Old Sep 20, 2014 | 05:54 AM
.M.'s Avatar
.M.
Next time you get gas, hold it by hand and let us know.
Old Sep 20, 2014 | 05:28 PM
1ucky11's Avatar
I will try tomorrow im filling up. I'll let you guys know what happens
Old Sep 20, 2014 | 06:36 PM
Thomar's Avatar
Ya, some pumps have too high of a flow rate; gas doesn't pour into the tank fast enough. The gas accumulates and the nozzle shuts off.
Old Sep 21, 2014 | 04:50 PM
1ucky11's Avatar
Alright guys. The verdict is... same problem. I decided to go to another gas station and fill up. I set it on automatic, and this time when i got in the car it was full until i pulled out of the gas station. Weird... so, my next fill up I'm going to try to just hold it until it stops, which to me would be the same thing as setting it on auto stop. Right? What else should i try?
Old Sep 21, 2014 | 05:35 PM
.M.'s Avatar
.M.
Well, if anything take it to the dealer and have them look at it. I'm guessing you have warranty correct?
Old Sep 21, 2014 | 05:55 PM
1ucky11's Avatar
I hope so... i only have 1500 miles on it
