Sponsored by:
Sponsored by: CARiD
Bolt Missing off TurboXS exhaust
Old Sep 22, 2014 | 02:30 PM
Sephiron's Avatar
While driving I instantly heard my exhaust go from normal, to TERRIBLY loud. So I drove home and got under the car and one of the bolts from the top of whichever pipe is Forward of the midpipe. (Its that the front pipe?) I'm pretty sure I found the bolt here http://turboxs.com/shop/mitsubishi/1...ront-pipe.html
It's a M10x40x1.5 if I am right. But It doesn't show what kind of metal it is.
Should any bolt I find at a hardware store with the correct specs work?
Also, I have had to drive on it for two days now. Will driving on it cause any harm? I'm trying to stay out of boost as much as possible.
Thanks!
Old Sep 22, 2014 | 02:56 PM
.M.'s Avatar
.M.
The grade of a bolt has nothing to to with what temperature it will hold up to. Grades are a standard of tensile strength..... And the exhaust doesn't require a bolt of even grade 5 strength (for example). So don't worry about it. If you can find the right bolt(s) locally, go for it.
At my old job (diesel mechanic) I use to grab the right size, zip it on, good to go. Nothing special about them. Used on everything from mirror brackets to downpipes. It was nice because we had every size. Both metric and standard. Came in real handy when I needed a random nut or bolt for the car or motorcycles
I think you should be fine driving. Obviously you're probably not going to get on it since the car is extremely loud now. If it worries you at all, just go easy on it.
Old Sep 25, 2014 | 11:09 AM
RocketSkates14's Avatar
You will be fine with a joe schmo home depot bolt.
Old Sep 25, 2014 | 02:45 PM
Sephiron's Avatar
Awesome. Thanks guys.
I ended up getting the bolt at Napa and got it in after a long while of trying to get the flange to align.
But I think I am missing a spacer of some kind because all its doing is compressing the spring and not actually clamping down at all. I had an exhaust shop look at it and they are going to try a few things to try to get it to seal again.
Old Sep 25, 2014 | 03:10 PM
PSUfan1's Avatar
Are you using the stock doughnut gasket and spring bolts and the stock downpipe? When I added a test pipe and cat back I just used a 3" flange exhaust gasket and hardware from Lowes. This was after the supplied hardware and gasket vibrated off. I found that wave (lock) washers at that location help a bunch. That being said I have a double set of nuts at that flange. No problems with it since.
Old Sep 25, 2014 | 04:30 PM
.M.'s Avatar
.M.
An exhaust shop should have no problem with something like that
Old Sep 30, 2014 | 07:59 PM
R Lar's Avatar
I had this happen. Bolt came off that attached the mid pipe to the cat. Use a lock washer and it's been holding up ever since. Also, used a bolt from Lowe's.
Old Oct 1, 2014 | 08:04 AM
Sephiron's Avatar
The exhaust shop said that the bolt that I put in wasn't actually going in because the downpipe was stripped on that left side. (how does a bolt just strip out of its place on its own?)
So they ended up getting a longer bolt and putting a lock nut of some kind on the end and that fixed that. On the other side, they broke the bolt off in the downpipe so they had to spend a while getting that out without damaging those threads.
All in all, $250 for 3 hours of labor and some parts and its good as new!
Now that I think about it, the non mitsu dealer that replaced my clutch probably messed up that downpipe thread. Wouldn't surprise me considering they blew my AYC pump, an input shaft seal and blew the CMC while trying to replace the clutch.
Old Oct 1, 2014 | 11:38 AM
.M.'s Avatar
.M.
^Yikes
Well, at least its fixed now
GFinley
Dec 10, 2015 09:26 PM
nystc23
35
Apr 17, 2015 01:59 PM
patkelley
Oct 16, 2014 05:34 PM
4g63girl
Mar 31, 2014 12:11 PM
MivecAddict
Apr 4, 2012 07:18 AM
