Sponsored by:
Sponsored by: CARiD
Sway bars feeling softer over time
Old Jan 14, 2015 | 07:27 AM
hispanicpanic's Avatar
Originally Posted by Iowa999
Please don't write this sort of thing. Now all of the people who still believe that the ACD can alter the native torque split will be jumping up and down, screaming "I knew it!"
or should i say, engagement of the center diff sending power to the front was extremely delayed, causing the setup to essentially operate as a rwd below 5.5k rpm?
Old Jan 14, 2015 | 12:46 PM
Iowa999's Avatar
Just talking about the center diff locking. Until it does start to lock, 50% of the torque is sent to each end of the car and this is the issue on which too many people are confused.
Old Jan 15, 2015 | 10:52 AM
sgtr275's Avatar
I think it would be more accurate to say that until it starts to lock, it sends more power to the axle with the least amount of traction.
Old Jan 16, 2015 | 08:23 AM
Originally Posted by sgtr275
I think it would be more accurate to say that until it starts to lock, it sends more power to the rear.
fixed
Can't send power to the front if there's no hydraulic pressure in the ACD line.
Old Jan 16, 2015 | 09:17 AM
sgtr275's Avatar
Originally Posted by hispanicpanic
fixed
It can't decide to send power anywhere. It starts as an OPEN differential and locks with increasing hydraulic pressure. An open differential sends more power to the side with less traction. At full lock, the differential sends 50% of the power to each axle.
Old Jan 17, 2015 | 08:57 AM
Iowa999's Avatar
No. Just, no.
A locked diff can distribute torque (and, therefore, power) at any split from 0-100 to 100-0, assuming it remains locked.
Old Jan 17, 2015 | 11:38 AM
sgtr275's Avatar
No. Just, no.
This is how I understand the mitsubishi ACD to function. I have seen no information to the contrary.
http://www.full-race.com/store/r14-a...troller-1.html
Edit: Okay, I think we are talking about different things. I am referring to differential torque split and not power distribution. Slightly different things, albeit related.
Old Jan 17, 2015 | 02:59 PM
sgtr275's Avatar
No. Just, no.
You're right. I had it backwards when I typed it out. Was thinking about one thing and typing something else.
Old Jan 18, 2015 | 05:34 PM
Iowa999's Avatar
If you go to that page and look at the labelled picture of the pump, you will see that they either just cut and paste that picture without looking at it or they are totally clueless. I am so sick of that particular picture.
Old Jan 19, 2015 | 08:05 AM
sgtr275's Avatar
Which part are you referring to? The "no bleeding required"?
Old Jan 19, 2015 | 08:47 AM
Iowa999's Avatar
Is there a labelled picture of the pump with "no bleeding required" on it? I must have missed that one.
I'm referring to the picture that includes the claim that the pump has separate left and right solenoids for the AYC. The question I like to ask folks who defend that picture, since it was handed down by some godfather of bygone dance-styles and I'm nothing if not sacrilegious, is why one of the solenoids has two connectors and the other has only one. Then I watch for the ear-issuing smoke.
abevAWD
May 3, 2009 10:21 PM
04rallikid
Jun 11, 2008 02:13 AM
Speed Ball
18
Aug 15, 2006 11:55 AM
J8dailo
Feb 13, 2006 04:27 AM
Annoch
Sep 27, 2004 04:55 PM
