Sponsored by:
Sponsored by: CARiD
Front O2 sensor question
Old Dec 15, 2014 | 05:10 AM
jvaz1985's Avatar
Had this on another part of the forums and over 100 views but no answer. How do you know when it is time to change these. Recently at a tuner shop and after a computer scan/diagnostic said that i had a bad front O2 sensor that was stuck in lean position causing an erratic idle.
My FPR hose is already sealed in place and clamped so thats not the problem. I recently got the timing chain, guide and tensioner replaced with the stronger revisions so thats not the case.
Gott a cobb accessport v3 and that has helped a little but i see that they say to get and upgraded fuel pump relay (the blue one) and i am getting that.
Said my voltage readings for the front were less than 1 volt and that it should read at least that or higher.
Any help is greatly appreciated!
prowakeskater
Jul 7, 2011 12:38 PM
BoostinBird
May 11, 2010 04:17 PM
ernald711
Mar 18, 2010 10:47 PM
Raceghost
Mar 12, 2009 11:47 AM
Boost3dxEvO
Jul 8, 2008 01:32 AM
