Sponsored by:
Sponsored by: CARiD
Evo x O2 sensor problems please help
Old Feb 2, 2015 | 08:52 PM
EVOREZ1992's Avatar
I keep getting an O2 sensor code put a new o2 sensor in and on the obd2 scanner both my O2 sensors are reading but I'm still getting the code please help
Old Feb 3, 2015 | 10:13 AM
ikt's Avatar
ikt
is your car stock?
Old Feb 4, 2015 | 06:14 PM
EVOREZ1992's Avatar
no a bunch of mods
Old Feb 5, 2015 | 07:25 AM
hoobastnk90's Avatar
so what are the mods? Due you have a tune?
Old Feb 5, 2015 | 12:01 PM
import111's Avatar
What specific code are you showing?
Old Feb 5, 2015 | 01:19 PM
shekaar's Avatar
More code info would help. P0134?
Old Feb 5, 2015 | 01:31 PM
meckert's Avatar
no a bunch of mods
So whats "a bunch of mods". Did you disable the back 02? Are you running a test pipe instead of a cat? What kind of 02 sensor did you put in? Did you slice wires or buy a drop in OE quality sensor? What made you replace the 02's to begin with? What were you doing or what did you do when the code tripped?
So-- here are the general things to consider.
Common Problems That Trigger the P0134 Code
Defective Oxygen Sensor/Air Fuel Ratio Sensor
Defective Oxygen Sensor/Air Fuel Ratio Sensor Heater circuit
Exhaust System Leak
Intake Air System leak
Low Fuel Pressure
Defective Engine Coolant Temperature Sensor
Defective sensor wiring and/or circuit problem
PCM software needs to be updated
Old Feb 5, 2015 | 01:50 PM
My money is on that his tune or whatever he has most likely just has the rear O2 sensor disabled. And he replaced it for no reason. Usually its pretty rare to have those sensors go bad especially on our cars since they still are fairly new.
nlp187
Jul 8, 2012 10:32 PM
BoostinBird
May 11, 2010 04:17 PM
DIDYSIS
May 9, 2009 04:30 PM
Cinci Turbo IX
Oct 26, 2007 09:57 PM
