Sponsored by:
Sponsored by: CARiD
Intercooler piping
Old Mar 9, 2015 | 03:21 PM
elkazX's Avatar
Intercooler piping
So I currently have cobb intercooler piping and wanted to paint it gold. Is there a good way to paint it myself or any way to make it a nice shiny gold? Or should I just get it powdercoated?
Old Mar 9, 2015 | 03:30 PM
meckert's Avatar
There is always a way-- just takes time and patience and prep work is the key. Sand, sand again, finer paper and steel wool, not missing anything. Prime with a good quality primer in a light coat and prime again in a cross pattern once first coat is dry. Sand again with steel wool, paint top coat several light coats. Clear coat if you like. Prep and sanding is everything or depending on your attitude--nothing. Now tell us, Can you paint your intake pipes gold? lol.
Old Mar 9, 2015 | 05:52 PM
elkazX's Avatar
Okay sweet I will do these here soon and probably post pictures on how it came out. Is there a certain type of paint I should use? Im assuming high temp would be a good idea.
Old Mar 10, 2015 | 04:37 AM
meckert's Avatar
Wink
don't know if you can find HT gold---but you can find HT clear.
Duplicolor makes a good paint. Take your time and let everything dry between coats and don't touch!
Old Mar 10, 2015 | 06:45 AM
hoobastnk90's Avatar
Or...instead of doing all that extra work you could just find someone to powdercoat them gold for you! It will resist heat and be easier!
Old Mar 10, 2015 | 01:07 PM
elkazX's Avatar
So just sand it down and do everything like you said and then use the color I want and then clear coat? Thanks for your help!
Old Mar 10, 2015 | 01:08 PM
elkazX's Avatar
Yeah Ive thought about this but why waste money on something I can also do myself. Helps me save money for other parts
Old Mar 11, 2015 | 08:31 AM
Veronica's Avatar
-OR-
Use self-adhesive gold foil.
http://soontomax.en.alibaba.com/prod...ive_paper.html
Old Mar 12, 2015 | 12:10 PM
elkazX's Avatar
Originally Posted by Veronica
wouldnt be a bad idea if i could order it from somewhere in the US and not a huge shipment of it haha
Old Mar 12, 2015 | 12:41 PM
HEY !
http://www.streettunedmotorsports.co...ect_a_gold.htm
Old Mar 13, 2015 | 05:26 AM
Veronica's Avatar
^ good find!
Now, to be clear, this a cosmetic mod, right? Because the gold foil heat shield will protect a component from external heat.
It will not help your intake charge run cooler (shed heat from the turbo). The upper pipe is hotter than the engine bay temperature - so, by wrapping/painting it - you actually trap heat in.
You could make an argument for wrapping the lower pipe...
Old Mar 13, 2015 | 06:34 AM
Pretty sure thats why he is doing it... but i uno lol
Old Mar 13, 2015 | 07:23 AM
elkazX's Avatar
I'll prob end up going with that foil! It wouldn't make anything hotter than those things normally would be right? I know the piping gets hot of course but I see the foil resists heat up to 850 degrees so im assuming there wouldn't be any issues running this foil? I don't wanna start a fire in my engine bay because of this stuff lol
Old Mar 13, 2015 | 09:12 AM
i think if you google it there are pictures of an ams car that used the gold foil on the pipes with no problems!
Old Mar 13, 2015 | 12:51 PM
elkazX's Avatar
Yeah I feel like I've seen the gold foil before. Gonna go ahead and go with it since it saves a lot of work as well
