Sponsored by:
Sponsored by: CARiD
Boost gauge vacuum line size
Old May 7, 2015 | 08:29 PM
domsevo's Avatar
Hey guys, have a quick question. Just finished installing my AEM boost gauge today and used 7/64'' vacuum lines. I believe AEM typically sends 1/8'' lines with their boost gauges but I bought it off someone used so I did not get those. After installation, I turned on my car and it's reading -20... My accessport is around -8 which I believe is normal for the car at idle (I think). The cars own vacuum line that I splice into (and T-jointed) is a good amount bigger than 7/64''. Is the reason that I'm getting this weird reading because of the change in vacuum line size at the T-joint? I attached a picture to help understand, in case my writing is not clear. Thanks in advance
Old May 8, 2015 | 07:10 AM
Projectjdm's Avatar
That's normal the boost gauge reads vacuum in inhg vs Cobb accessport that reads in psi. Use a conversion to translate it.
Old May 8, 2015 | 08:49 AM
domsevo's Avatar
Perfect! They are the same. Thanks
Old May 8, 2015 | 09:57 AM
yifuqiao's Avatar
Your reading is good man. But that t fitting looks way too big for the sensor line.
I used 1/8 x 1/4 x 1/4 from autozone and it fits perfectly.
I think as long as all the lines Snug fit, you will be good.
Old May 8, 2015 | 10:27 AM
Projectjdm's Avatar
No problem. It's a common mistake that people make on their first boost gauge install.
Done
Aug 17, 2008 04:07 PM
CaliMR
Nov 9, 2007 10:49 PM
saiyanzzrage
Jan 21, 2006 10:14 AM
Mr. Stock
Nov 10, 2005 06:37 PM
