First oil change
First oil change
About to do my first change at almost 2,000 miles. I see people recommend 0w40 from mobil 1. The only one I see says european formula, is that the one or is there another 0w40 mobil 1? Thanks
T6 is 5w40
I used a ea15k13 filter. I don't know if it's overkill because it's rated for 15k miles but I'll probably swap it out my next oil change.
Changed my oil at 1.5k miles and I'll change again around 4k.
http://www.amsoil.com/shop/by-produc...ode=EA15K13-EA
Changed my oil at 1.5k miles and I'll change again around 4k.http://www.amsoil.com/shop/by-produc...ode=EA15K13-EA
[QUOTE=hydro334;11449003]T6 is 5w40
http://www.amsoil.com/shop/by-produc...ode=EA15K13-EA[/QUOTE
Is there a lot of people running the rotella t6? Would mobil 0w40 be any "better"?
Changed my oil at 1.5k miles and I'll change again around 4k.http://www.amsoil.com/shop/by-produc...ode=EA15K13-EA[/QUOTE
I think quite a few evo owners run it.
I'm a newbie but I researched it for a while on here and other forums. It seems like mobil is more likely to shear/thin out at higher temperatures faster than other oils. No test I saw showed it to be any better than other oils out there.
Apparently most oils don't have as many additives anymore but T6 seemed to still have pretty good numbers.
You guys actually recommend 40weight oil?
What is the reason behind it?
Does it depend on modification level of your car? Or application of the car? I can see if you road race a lot, 40 weight might make sense.
I have been following factory recommend 5w30 since 1st oil change.
sweet jesus i did some more research on oil and man there is like a never ending debate lol.. Although the Rotella stuff has pretty much nothing but good reviews all of them seem to be for the 4G platform.. i couldnt find much about our 4b11... i would be interested in trying the rotella if it was actually safe.. but hard to find much info about our X
